Any suggestions/thoughts will be appreciated because although I'm a decent shade tree with plenty of tools and pretty broad experience, I've never touched a diesel engine. I've spent several days searching the web and reading. I think I have a combination "dusted engine" and, at the least, a blown head gasket. My hope is that I can restore this tractor to useful life by installing a minor overhaul kit without pulling the engine.
Here's the bullet points:
1. MF 231 - Perkins 3-152 -- a friend's tractor that I've been using on his property to mow and till. I'm going to try to fix it. I am having no luck finding a piston/ring/minor overhaul kit? Every site has kits for 230, 240, and 250 and a bunch of other 152 engines but no one mentions the 231 (Polish) but my guess is they are all the same? Big guess. I'm going to do this without pulling the engine. I'll call a MF dealer and ask but if anyone has 231 and bought a kit that worked I'd be grateful for the source.
2. This tractor, when purchased a couple years ago, originally had bad head gasket. My friend had it fixed. Probably 100 hours ago. Don't know the details of the repair. Had someone change fluids--my wrong assumption was they also checked the air cleaner system. Don't know how many total hours on the tractor.
3. Noticed blow by a couple weeks ago. Oil was escaping out of the dip stick, and around oil filter. Before that, I had noticed white smoke was coming out of the bypass hose under the tractor. Didn't notice any white exhaust smoke from the stack. I did not know about "dusted engines" as this time. Blow by means bad rings is what I've read. Dirt in the air system causes that, I've read. Now I'm thinking that the white smoke was probably water being vaporized.
4. It still ran fine, but then the other day when I parked it I noticed water coming from the radiator overflow. Didn't show hot on the gauge, but it was way low on water, like 8 quarts low (only holds 9). I'm sure it had to be hot. No external leak noticed, no history of leaks, I'd topped it off earlier in the year. Can't say how long it was run low on water. Bigger mystery is what happened to cause it? My guess is head gasket given the fact there was no hose leak or radiator leak that I saw. I need to get a pressure tester to confirm.
5. Got to checking the tractor out and find out the air cleaner system is shot. Holes in the hoses, oil bath fallen off, dirt everywhere. I'm sure its been sucking dirt for a while. "Dusted engine" situation so I've read. I don't know how this would be directly related to the dry radiator issue.
6. Now the engine won't start, although it ran a week ago when I parked it when all this came up. It also started right up before. Good battery, but I'm double checking on that and will make sure its cranking speed is good before I move on. I don't know if I will be able to do a compression test (tool issue). When I try to start it after a bit it starts to puff white smoke as its cranking but really doesn't act like it is going to start....I've read than means water is getting into the cylinders, which makes sense since if the head gasket is blown (or head cracked) and the radiator is getting sucked dry through the head gasket. The air cleaner system is off of it (waiting for parts) but that shouldn't make it not start I wouldn't think. I gave it just the smallest shot of ether (I know that's bad) and it did pop but I didn't want to continue to use ether because of all the bad press. And I don't think its fuel related but haven't bled any lines, etc., because I'm not sure how to do so yet and don't want to get more sytems messed up because of my incompetence.
7. Can I confirm the head gasket is blown by putting a pressure tester on the radiator or by filling the rad. clear full and cranking it to see if water shoots out (read that somewhere)?
8. Assuming I buy a shop manual, take pictures, and am careful, how big a deal is it to do this job and what suggestions do you have? The kits, assuming I can find one for the 231 engine, are not badly priced but to have a shop do it would be a deal killer. Also, I think I might as well do the rod bearings (do you just use std size if the crank isn't ground?) and can the mains be done without pulling the engine?
9. I'm surprised I haven't been able to find anything on You Tube or on the net on how to overhaul a 3 cyl Perkins diesel since there are so many of them used in so many applications. If I could watch or read about they process I'd feel a whole lot better. I haven't read how you get the sleeves out but that sounds like a great idea if it isn't a pain to get them out. I assume I can have a shop check the head and put in the valves just like a gas engine.
9. Finally, the tractor has a 232 loader on it....I'd sure like to avoid taking it off to do this work...any thoughts on that? I know I'll have to take the fuel tank off and then with the loader assembly I'll be leaning over a bit and it might be a little less convenient but I'm just not crazy about opening up any hydraulic system for fear that I'll mess that up in the process.
10. Any and all tips/directions/guidance of any nature, and where to get specific 231 kits, will be appreciated. My first choice will be to get the engine ID and call a MF dealer to get a factory MF kit. Unfortunately, I don't have a local dealer but there are some in the state.
