MF 231 with Loader and rear hydraulic connectors.
I'm not real swift on working the loader and the 3pt. I can get everything to work, but the markings are worn off the draft control and things don't seem to work quite like the owner's manual says they should on the 3pt. The loader seems slow to respond and I don't think it lifts as high as it should. Fluid is good. I can get the 3pt to raise the tiller up to the "transport" position but have trouble getting it to lift and hold the tiller just a few inches off the ground. Again, that might just be me and I need to reread the manual.
But the culprit might be this valve control that sits right under/front of the seat. But the owner's manual doesn't mention it and I don't know where its supposed to be when running the attachments so I have it straight up.
Can anyone tell me if this is right or where this valve should be positioned for different tasks? Thanks
