Results 1 to 6 of 6
  1. #1
    Silver Member bsbrum's Avatar
    Join Date
    Nov 2011
    Posts
    106
    Central Ohio
    1959 MF 65
    Default Steering box vent leaking
    Am on my second MF65 and they both weeped rusty looking oil out the steering box vent hole that is just under the dash panel.
    This is a closed box on the MF65 - no connection to the power steering pump like a 35/135.
    Is this common, and what's the fix?
    It makes a dickens of a mess.
    Much thanks!
    Brian (Central Ohio)
  2. #2
    Join Date
    Mar 2012
    Posts
    236
    Akron, IN
    MF 85 diesel, TO 35 diesel, 165 diesel, IH Hydro 84 diesel, MF Super 90 diesel puller, Agri Power 7000, 8000, and 9000 diesels, MF 205 diesel
    Default Re: Steering box vent leaking
    Sounds like condensation water buildup along with oil has box overfull. Best to drain and refill to level plug with new oil. Don't think there is a drain plug though, may drain out of some lower side cover bolts if they were drilled through. If not can loosten all cover bolts, bump arm end to move cover away about 1/4 inch to drain out what you can, then retighten and refill at plug on gearbox top side. What ever works be prepaired for a big mess, will take awhile to drain old thick oil.
  3. #3
    Join Date
    Nov 2011
    Posts
    106
    Central Ohio
    1959 MF 65
    Quote Originally Posted by Dieseltech View Post
    Of course, and water is going to drop to the bottom, pushing the oil out.
    Grrrr! What a pain. :-)
    Thanks much, Dieseltech!
  4. #4
    Join Date
    Nov 2011
    Posts
    106
    Central Ohio
    1959 MF 65
    Default
    There is a drain plug...
    Steering box vent leaking-image-213042705-jpg
  5. #5
    Join Date
    Mar 2012
    Posts
    236
    Akron, IN
    If yours has a drain plug you are lucky, just looked up steering box service in original operator manual, shows side cover must come loose as no drain plug is on assembly. Had to replace complete box on cousin's 65 last summer, never found a plug on his either. His was so bad it was not worth repairing, enough water had gotten inside it froze and pushed out welsh plug years ago, lost any oil it had and ran dry for years. Sits out all the time, is one tired tractor, but he still runs it as is.
  6. #6
    Join Date
    Nov 2011
    Posts
    106
    Central Ohio
    1959 MF 65
    Default
    Dieseltech, you were right on both counts.
    I had no drain plug, and I drained about a quart of water out of the steering box - I just cracked the case and let it leak out.
    Many thanks!
Similar Threads
  1. Ford 800 hard steering to left
    By george46 in forum Parts/Repairs
    Last Post: 05-31-2017, 12:15 PM
  2. Steering box for Kubota B8200D
    By abnorml in forum Parts/Repairs
    Last Post: 01-08-2015, 11:35 AM
  3. B series steering cylinder leaking
    By yellowdogsvc in forum Toolcat
    Last Post: 03-03-2010, 02:17 PM
  4. JD 317 steering box
    By Wheatland KB in forum John Deere Lawn & Garden
    Last Post: 08-22-2009, 07:17 PM
  5. BX 2200 Power Steering
    By Anonymous Poster in forum Kubota Owning/Operating
    Last Post: 06-15-2003, 10:47 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
