Results 1 to 5 of 5
04-27-2012, 08:17 AM #1New Member
- Join Date
- Mar 2012
- Posts
- 6
- Location
- leicester ma
- Tractor
- massey ferguson 1235
04-27-2012, 01:50 PM #2
Re: Bell Housing Cracked? Massey Fergusson 1235
Expensive would be the guess on cost.
Looks like a backhoe subframe in the pics, so that shouldn't be a cause. Heavy loader work with loose mounts? What type of work were you doing when it happened?
04-27-2012, 05:11 PM #3Veteran Member
- Join Date
- Dec 2008
- Posts
- 1,278
- Location
- Up-State New York
- Tractor
- Grand L 3540 HST-3, R4's
Were you digging with your hoe? Looks like a stress crack make sure all bolts for frame mounted backhoe are tight. Afraid it's going to cost mucho$$$$, good luck.
DevilDogHe is your Friend, Your Partner, Your Defender, Your Dog. You Are His Life, His Love, His Leader. He Will Be Yours, Faithful And True, To The Last Beat Of His Heart. ...Unknown
05-17-2012, 04:35 PM #4
Replacement bell housing will come with 2 reinforcement straps. There is a service bulletin on it released around 2003 or so. Ask your deaer to look it up.
08-29-2012, 03:15 PM #5New Member
- Join Date
- Mar 2012
- Posts
- 6
- Location
- leicester ma
- Tractor
Welll Just a follow up. I ended up having to shell out $4200 clams to get this fixed. The whole clutch system bellhousing replaced and the FEL mounts were broken which probably caused my problem??? Anyway the repair shop didn;t tell me much of anything on how or why. I also had to take them at face value this was what it cost to repair. Kinda sucks being a novice.
Similar Threads
replacing my hinomoto c-174 bell housing
By Brian Kienenberger in forum Grey Market TractorsReplies: 0Last Post: 04-16-2008, 09:31 PM -
Bell Housing recall
By stobswan in forum ToolcatReplies: 5Last Post: 01-14-2008, 06:16 PM -
TC24DA Broke in half behind Bell housing !!!
By shaggy in forum New Holland Owning/OperatingReplies: 12Last Post: 04-15-2005, 08:15 AM -
cracked axle housing
By Anonymous Poster in forum Kubota Owning/OperatingReplies: 30Last Post: 12-08-2000, 02:05 PM
