Results 1 to 6 of 6
  1. #1
    Veteran Member cdaigle430's Avatar
    Join Date
    May 2010
    Posts
    1,054
    Maine
    MF GC2410
    Default TSC CountyLine Post Hole Digger
    Hi,
    Looking at a 3ph digger for my GC2410-TSC has one for sale at a pretty decent price and I was hoping someone here has one setup on their GC series. Will it fit my GC2410 and how reliable? Any tips?
    CountyLineď˝® Post Hole Digger
    Manufacturers Number: 24045500
    Brand: CountyLineď˝®
    Hitch Category: 1 & 2
    Boom: 2-7/8 in. High Strength Tubing
    A-Frame: 2-7/8 in. High Strength Tubing
    With a 6" auger I'm looking at $600.
    2010 MF GC2410 TLB, 2006 Husqvarna YTH 2448, 2004 Honda Rincon 650, 2007 Honda Shadow Aero 750, 2006 Jeep Grand Cherokee Limited-Hemi.
  2. #2
    Advertiser EverythingAttachments's Avatar
    Join Date
    Mar 2009
    Posts
    3,618
    Newton NC
    Which One do you want to know about?
    Default Re: TSC CountyLine Post Hole Digger
    I'm doubt the TSC post hole digger will work because they don't mention compatibility with subcompacts. We manufacture a post hole digger especially for small compact/subcompact tractors so you'll have enough clearance to lift the auger out of the ground. They are equipped with a 2" round output shaft and use a standard 48" auger. We offer free ground shipping to your door within 1000 miles of Newton, NC and very reasonable shipping rates outside of the free zone. Check out the details and video on our website here. You can't go wrong with an EverythingAttachments post hole digger!!
    Ted Corriher
    www.EverythingAttachments.com
    1-866-581-5818
    A family-owned American Company that also sells quality Made in USA Implements every chance we get! We pride ourselves on giving good product information and putting the needs of our customers above our own!
  3. #3
    Join Date
    Jul 2003
    Posts
    1,926
    Central VA, USA
    Mahindra 6000 MWFD, 2 1950's Farmalls, 1974 Farmall 140, 1967 Mf 135Delux
    I have the unit you are looking at...I use it on a Farmall and a Massey F 135....I got the 12" auger...works well, but I'm thinking if you try it on sub-compact, you probably will be disappointed....BobG in VA
  4. #4
    Join Date
    May 2010
    Posts
    1,054
    Maine
    MF GC2410
    Quote Originally Posted by EverythingAttachments View Post
    I'll have to give it a think.
  5. #5
    Join Date
    Jun 2011
    Posts
    188
    Manitoba, Canada / Minnesota, USA ( I straddle the border)
    '12 Kubota B2620, fel,mmm,bh,bb
    I bought one 5 weeks ago and just sold it for almost same price I bought it for. I made the fence holes I needed and didn't think having it sit around would create any value for me.
    9" auger and used it to make 180 holes for a fence I put around my cabin that sits on 5a. 39" field fence (9-39-6) plus 2 single strands of 12g cl 3 galv. wire above to protect the field fence in case a tree fell on it. We are in a 100% treed lot with no open space other than what we cut.
    Auger worked flawlessly and I dug the holes 4' deep with 4' of post above ground. If you go to the SpeeCo website they make the Tractor Supply one I bought (said on back of users manual) and stickers saying SpeeCo on some of the parts still
    I used it on a kubota B2620. After 180 holes looked like brand new other than some paint wearing off the carbide cutting edges.
    tricks?
    1)slow on the rpm. 1,100 - 1,200 worked great. Too fast and the holes go out of rnd and the auger wobbles. No need to spin it fast as it dug the 4' hole in less than a minute even after raising the bit 1x-2x to keep hole clean.
    2) slow on dropping the auger with the 3pt hitch control. Drop too fast and auger bit would lean to one side. Any sign of going off vertical and a quick little up tick of the 3 pt control and the lean straightened itself right out.
    3) clean the hole during the drill process. 1/2 way through a 4' hole I would lift the auger almost out of the hole to clear some of the cutting out. Otherwsie when it got down to the bottom I feared it just might not pull out at the lower rpms.
    the Speeco site says will Class 0, 1 or 2 3 pt will work up to 65hp.
    Comes with bushing for Cl 1 and 2 in the kit already from TS.
    if I had unlimited cash then for sure I would have prefered to pound the post in OR a hyd. unit that has more finese control would be prefered. But at $550 for auger, cutting edges, spiral bolt on pt, and the post hole unit I had no complaints.
  6. #6
    Join Date
    Jun 2011
    Posts
    188
    here is the link to the SpeeCo website and model of digger that TSC carries.
    SpeeCo Inc. - Log Splitter, Tractor Parts, OEM and Farm Accessory Contact information
    Attached Thumbnails Attached Thumbnails TSC CountyLine Post Hole Digger-auger-jpg
Similar Threads
  1. Post Hole Digger - if stuck
    By The Gardener in forum Owning/Operating
    Last Post: 05-31-2009, 01:30 AM
  2. Posthole Digger Trouble with post hole digger
    By jester7891 in forum Attachments
    Last Post: 05-06-2007, 10:34 PM
  3. Post Hole Digger on a BX
    By AceDeuce in forum Kubota Owning/Operating
    Last Post: 04-04-2007, 04:33 PM
  4. Engaging a post hole digger on a TC29D
    By Mosey in forum New Holland Owning/Operating
    Last Post: 05-08-2002, 05:06 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
