Results 1 to 5 of 5
  1. #1
    Join Date
    Jul 2011
    Posts
    75
    NW Ohio and SE Michigan
    Oliver 880, Ford 8N, Ford 9N, Farmall Super C, MF 205, Ford 4400 FEL, Ford 4500 FEL/BH, Cat D-6 Dozer(1957)
    Default Need cylinder head for MF 205 diesel
    Would you believe it from my most recent posts I was looking for a rototiller that my MF 205 could handle. Yesterday as I was cutting tall grass with my belly mower with a new belt and 3 new cutting blades, it started to steam from under the hood. The stem and cap from the radiator had blown off and the radiator was empty. Hours before I had put in a new battery and checked the radiator level and filled the fuel tank. I re-soldered the stem/cap back to the top of the radiator and filled it with coolant. I tried to start it today and it wouldn't fire. then i noted water leaking from the bottom of the exhaust pipe connection to the exhaust. Long story short, step by step dismantling finally took off the head and sure enough the head gasket was shot as well as a small crack in the head. I need a new head. Anyone suggest where they can be found and obtained.
    MF 205
    series 2745
    Sn 101952
    Assume it is a Perkins but not sure
    fuel pump is a KIKI diesel 104302 6640
    Attached Thumbnails Attached Thumbnails Need cylinder head for MF 205 diesel-img_0261-copy.jpg   Need cylinder head for MF 205 diesel-img_0260-copy.jpg
  2. #2
    Join Date
    Mar 2012
    Posts
    164
    Akron, IN
    MF 85 diesel
    Default Re: Need cylinder head for MF 205 diesel
    Engine is Toyosha, where is head crack location, maybe it can be repaired?
  3. #3
    Join Date
    Jul 2011
    Posts
    75
    Dear Dieseltech: Thank you for your reply. I am having some difficulty running down a source for a new head but found one in Canada (gplussier@sympatico.Ca). I have attached 3 pictures , 2 showing the crack in the head and one of the numberstamp on the engine block. The crack is as you face the picture at the left hand cylinder at about the 6 o'clock position. Is the number on the block : S 107 MO 3129 of any significance or only a casting source?
    Thanks Again
    Attached Thumbnails Attached Thumbnails Need cylinder head for MF 205 diesel-img_0252.jpg   Need cylinder head for MF 205 diesel-img_0257.jpg   Need cylinder head for MF 205 diesel-img_0258.jpg
  4. #4
    Join Date
    Mar 2012
    Posts
    164
    Akron, IN
    MF 85 diesel
    I have a 205 also but head has never been off. Not sure if crack is near water passage, depending on crack location it may not need replaced, but head gasket only may fix it. May need to pressure check head to be sure, have seen some heads crack through valve seats that caused no trouble. Will be away awhile but keep us posted as to what you find out.
  5. #5
    New Member
    Join Date
    Jun 2012
    Posts
    9
    st. louis, mo
    Massey ferguson 210-4
    Assume you have tried agco. A helpful dealer will do a old stock search for you. I called agco the otherday for a set of piston rings (MF 210-4 ) w/ Toyosha 2 cyl deisel, they were exspnsive but they had them. Tractorhouse shows salvage yards with several tractors like yours parted out.
Similar Threads
  1. MF 205 diesel with belly mower
    By docrocky in forum Massey Ferguson Owning/Operating
    Last Post: 09-08-2012, 02:33 AM
  2. Oil & Fuel MF 205 compact diesel question
    By diyDave in forum Massey Ferguson Owning/Operating
    Last Post: 02-10-2012, 09:00 PM
  3. I re-torqued my cylinder head.
    By Zork in forum Zetor, Century & Branson
    Last Post: 12-10-2011, 02:52 PM
  4. looking for Shibaura cylinder head
    By spierce1619 in forum Parts/Repairs
    Last Post: 06-18-2010, 05:55 PM
  5. cylinder head
    By frank360 in forum Massey Ferguson Owning/Operating
    Last Post: 12-01-2005, 07:05 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
