Results 1 to 4 of 4
  1. #1
    New Member
    Join Date
    Jun 2012
    Posts
    1
    lexington,nc
    Massey Ferguson 2615
    Default 2615 lift issue
    I'm having lift probems on my 2615. sounds like the PTO is engauged when all the way up and the lift seems to bounce and if I press the cluth in the lift will drop. Please help
  2. #2
    Join Date
    May 2007
    Posts
    64
    Default Re: 2615 lift issue
    I'll answer what I can since you have no replies yet. On most Masseys it is normal for the lift to drop when you push in the clutch because the pump only turns when the clutch is out. If you have a two stage clutch you can push the clutch half way in and shift gears without the arms dropping. Not sure what you mean by "sounds like PTO is engaged when all the way up".
  3. #3
    Veteran Member radrock's Avatar
    Join Date
    Dec 2011
    Posts
    1,466
    S/O Joplin, Missouri
    Massey Ferguson 1526 Hydrostat
    Default
    Isn't that a fairly new model? Does it have a FEL? My tractor had trouble with the three point hitch not lifting and was bouncing on the way up. Come to find out it was a problem with the relief valve on the loader itself.
    George
  4. #4
    Join Date
    May 2005
    Posts
    711
    SE Indiana
    Ford, Kubota, Massey Ferguson (Never Again)
    The lift should NOT drop when you depress the clutch.
    MF shipped many (most?) 2600 series tractors tractors with lift issues. Take it back to your dealer for warranty repair.
    SDT
Similar Threads
  1. JD 70A lift speed issue
    By Mechanos in forum Hydraulics
    Last Post: 07-13-2011, 10:46 PM
  2. 3-Point Hitch 2615 lift adjustment
    By 69x11 in forum Mahindra Owning/Operating
    Last Post: 05-27-2011, 01:42 PM
  3. 2615 gear, having an issue...
    By SABULA FARMER in forum Mahindra Owning/Operating
    Last Post: 12-23-2009, 08:22 AM
  4. 2615 hydraulic line issue
    By Nickthegrip in forum Mahindra Owning/Operating
    Last Post: 04-21-2009, 10:20 AM
  5. MF 165 Lift issue
    By AllWaysBreakinSomething in forum Massey Ferguson Owning/Operating
    Last Post: 03-30-2007, 02:03 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
