Results 1 to 3 of 3
  1. #1
    Gold Member Rford's Avatar
    Join Date
    Jun 2010
    Posts
    259
    KC
    1966 Ford 2000 Diesel 8sp
    Default 4 ring or 5 ring piston...does it matter on rebuild of AD3-152?
    Called the MF dealership to talk about inframe rebuild kits and the salesman talked me out of ordering OE Perkins in lieu of a PowerMax kit. It was $320, arrived in a couple of days, and it looks like it is all there, in fact, it looks to me like they sent me two extra sets of main bearings.
    I have the odd-ball CE22666 build no. engine but the PowerMax manual had this listed. I noticed right off that the new pistons are 5 ring, not 4 ring. The pistons are the correct size but they have an extra oil ring below the wrist pin. The service manual shows 5 rings and not 4 and even mentions the extra ring as "Maxigroove" oil ring. So I'm thinking 4 rings or 5 is not important, probably an upgrade from 4 to 5 at one time.
    Any experts on the "Maxigroove" oil ring out there? Would this cause anyone a concern?
  2. #2
    Join Date
    Mar 2012
    Posts
    236
    Akron, IN
    MF 85 diesel, TO 35 diesel, 165 diesel, IH Hydro 84 diesel, MF Super 90 diesel puller, Agri Power 7000, 8000, and 9000 diesels, MF 205 diesel
    Default Re: 4 ring or 5 ring piston...does it matter on rebuild of AD3-152?
    Most naturally aspirated Perkins used 5 ring pistons, turbocharged used 4 rings, you should be OK with what you have, 5th ring helps oil control.
  3. #3
    Join Date
    Jun 2010
    Posts
    259
    KC
    Thanks...oil control will be good...it had major blow-by and oil shooting out of everywhere before the teardown....
Similar Threads
  1. Oil & Fuel perkins ad3 152
    By max kay in forum Owning/Operating
    Last Post: 07-29-2011, 08:38 PM
  2. Retaining ring or clip ring, can they be
    By Newtogreen in forum Parts/Repairs
    Last Post: 03-04-2010, 05:53 PM
  3. 2N 4-Ring piston question
    By DGaber in forum General Vintage Tractors
    Last Post: 06-04-2009, 10:08 AM
  4. Mystery O-ring on FEL piston near bucket?
    By Sniggle in forum Kubota Owning/Operating
    Last Post: 03-04-2008, 08:22 PM
  5. HELP! on L2202/L275 piston and ring size
    By tsterkel in forum Kubota Owning/Operating
    Last Post: 02-16-2008, 11:24 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
