mauricem
Member
Changed the fuel filter on the 253 the other week and havent had it going since! (did the water pump at the same time but thats another story) If you look at the image Ive bled it at all the points shown at the filter and the pump but have had problems getting a spanner onto the injector nuts.
Firstly is it the large nut that the arrow is pointing to that I need to back off? None of my spanners will get in their so I guess I need a flare spanner? 17mm is close but this would be AF wouldnt it 20 11/16" would be the one?
Hopefully bleeding one pot will do it as the one closest to the driver (is that 1 or 3 cyl?) looks impossible to access without removing the fuel tank. ANy ideas if I should be able to get a wrench in there past all the spaghetti?
You might notice in the pic a fair amount of oil around #2 injector seat, would this be from the rocker cover leaking down or the injector itself, should I be concerned? There is no oil usage or signs of leakage on the shed floor.
Tractor has been running well and usually starts immediately, Tank is full of fresh fuel. The only odd thing was when I replaced the MF fuel filter with a Donaldson the correct orientation going on the original, was with the writing (Donaldson) upside down. I tried the other way first but had no chance of sealing it.
Thanks for any help, Ive bled plenty of diesels before but never with such bad access.
