Results 1 to 2 of 2
  1. #1
    New Member
    Join Date
    May 2012
    Posts
    15
    Northern Mo
    MF240
    Default 1984 MF 240 Question
    I have a 1984 MF 240. I have mowed, plowed, and tilled with it without any problems. I bought it with 1850 hours. recently while tilling, and using the PTO set to match engine speed, I had the PTO selector shaft keep jumping to neutral. It didnt happen alot, just enough to be a pain and to the point where I was holding the selector shaft rearward to keep it engauged. Any ideas what caused this.? I was tilling dry ground that had been worked just 4 months ago.
    Thanks
    MoDeer43
  2. #2
    Gold Member
    Join Date
    May 2012
    Posts
    362
    Gidgiegannup Springs, Western Australia
    Massey Ferguson 148 .Chamberlain Super 70. Caterpillar D4. Chamberlain 354 FEL.Toro 268 rideon kubota L2002fel
    Default Re: 1984 MF 240 Question
    G,Day MoDeer43.
    If you were tilling extra hard ground and there was vibration there it could have shaken the pto out of gear I dont think so .
    If you remove the left hand sideplate the one with the pto lever on remove it and check that ,one the lever operates nice and tight that is it clicks in and out with no slack ,there is a spring and ball in there to hold the lever in position ,if the spring was broken this will cause the lever to drop out of gear.
    To strip down the cover and lever there is a roll pin that goes throught the pto selector shaft and lever,knock the pin out and check the spring,ball and the detents ,make sure the detents are not worn as some times they wear by being used a lot if the detent fork is worn it may be best to buy a new one.
    There ya go .
    Regards
    Hutch.
Similar Threads
  1. MF 240 Aux Hydraulic question
    By MoDeer43 in forum Hydraulics
    Last Post: 08-02-2012, 12:44 PM
  2. Yanmar 240 tranny question
    By ronofohio in forum Yanmar
    Last Post: 05-20-2011, 06:33 PM
  3. MF 240 Question
    By jgriswol538802 in forum Massey Ferguson Owning/Operating
    Last Post: 04-20-2011, 12:30 PM
  4. MF 240 question
    By wkheathjr in forum Massey Ferguson Owning/Operating
    Last Post: 08-26-2007, 12:59 AM
  5. YM 240 D Hydraulic Question
    By Rogerrl in forum Yanmar
    Last Post: 05-03-2007, 12:24 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
