Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
  1. #11
    Elite Member Gary Fowler's Avatar
    Join Date
    Jun 2008
    Posts
    4,735
    Bismarck Arkansas
    2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
    Default Re: Wel it's been a while since I tore something up......
    It is easy to see why it broke. They used the same welder that welded the pins on my LS seat suspension. Tack weld was so small you can barely see it. Same with that weld, very little throat in the fillet and only welded on one side at that. A good weld on it will fix it up.
    2010 LS P-7010C 20F/20R gear tractor & FEL, 2009 Kubota B 26 TLB, RTV 900 Kubota, 2012-20 ft 12k GVW trailer, 2011- 52" Craftsman ZTR mower, 54" John Deere 332 lawn tractor, 5.5HP rear tined walk behind tiller, 7 foot bush hog, 8 foot landscape rake , 8 foot 3 PH disc, 2 row cultivator, 350 amp CC/CV AC/DC welding machine and a shop full of tools that I spend more time looking for than using.
  2. #12
    Veteran Member Wacky's Avatar
    Join Date
    Apr 2010
    Posts
    1,074
    West Virginia
    2010 GC2610
    Quote Originally Posted by irvingj View Post
    JohnnyB- same as mine on the mower deck? Here's what I did:
    Attachment 283078Attachment 283079Attachment 283080
    Can't tell very well from the pic, but did you reweld the bracket? Looks like you just set the bracket inside and against the break.
    2010 MF GC2610--MF60"MMM--King Kutter XB 4' rotary cutter-- 4' King Kutter XB boxblade-- Ratchet Rake-- Check that parking brake
  3. #13
    Veteran Member irvingj's Avatar
    Join Date
    Feb 2008
    Posts
    2,171
    Etna, NH
    2005 MF GC2310 TLB
    No, Wacky, I didn't weld it.
    This was on both MMM lift arms, and as near as I can figure, that little angle piece is only there to keep the lift bar in better alignment to the attach points on both its ends; that is, to keep it toward the outside of the tractor where it attaches to the tractor frame.
    All I did was put a piece of thick-wall steel tube with washers on both ends in as a spacer around the bolt there (pic 3) to maintain the positional alignment -- and left that little angle off altogether. I doubt my system will break off like the original design did.
    Wel it's been a while since I tore something up......-dsc03404.jpgWel it's been a while since I tore something up......-dsc03403.jpg
    '07 GC2310 TLB, 2360 snowblower, 2325 MMM, Bro-Tek thumb, Woods GTC40-2 tiller, Woods RB-60 back blade, KK TYR-60 landscape rake, DR 60" Power Grader
    '05 VW Jetta Wgn TDI
    Numerous antique Japanese motorcycles
  4. #14
    Elite Member
    Join Date
    Oct 2006
    Posts
    3,241
    N.E., Ohio
    GC2310, Toro Reelmaster 5100D
    I dug a 140' trench for someone yesterday, the whole thing was on sloped ground, which was a first for me.
    If not for Wacky, I may not have been as careful.
    I did find out now, why manufacturers have gone to individual pedals, vs. the treadle. The tape measure which I had sitting on the floor of my tractor, had migrated under the pedal, while I was driving, (at high rate of speed).
    When I removed my foot from the pedal expecting to decelerate as I approached the gravel pile, I had just enough time to realize what had happened, and to reach down and remove the tape measure from under the pedal, as the bucket dove into the gravel pile.
    ADVISORY: DO NOT ALLOW FOREIGN OBJECTS ON THE FLOOR OF THE TRACTOR.
  5. #15
    Join Date
    Feb 2008
    Posts
    2,171
    Etna, NH
    2005 MF GC2310 TLB
    Uh-oh. I can see a new red "WARNING" sticker with an appropriate (but dumb) caricature/symbol being required to be retrofitted on our single-pedal tractors....
    But good advice, anyway-- thanks for the heads up, Ray.
    And yes, I think Wacky has saved a lot of us with his story!
  6. #16
    Join Date
    Apr 2010
    Posts
    1,074
    West Virginia
    2010 GC2610
    Quote Originally Posted by ray66v View Post
    Yes, I took one for the team. And you all are welcome!!
    Seriously though. I hope to have helped someone be a bit more careful on their tractors for their safety and others around them. And I have read a lot on here that has taught me as well! Thanks back to you guys. I always look forward to reading the Massey section, you all seem to keep it very informative and fun too!
Similar Threads
  1. TC35 A Help me figure out what I tore up.
    By Tim Stuart in forum New Holland Ag Tractors
    Last Post: 03-29-2011, 03:10 PM
  2. 1650 Oliver Tore Down
    By nwngunner in forum Parts/Repairs
    Last Post: 10-16-2010, 07:51 PM
  3. Well....I tore some stuff up today
    By MotorSeven in forum Kioti Owning/Operating
    Last Post: 11-06-2009, 08:10 AM
  4. Drive tore in half
    By Surewhynot in forum Attachments
    Last Post: 08-02-2008, 09:02 AM
  5. Tore up knee update
    By Shantycoke in forum Kubota Owning/Operating
    Last Post: 02-12-2008, 02:03 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
