Page 1 of 2 12 LastLast
Results 1 to 10 of 16
  1. #1
    Veteran Member Wacky's Avatar
    Join Date
    Apr 2010
    Posts
    1,074
    West Virginia
    2010 GC2610
    Default Wel it's been a while since I tore something up......
    Been doing some excavating with the ratchet rake and box-blade this weekend. Tried to climb a steep incline to get at some brush to pull down and tried to back down the hill. The tractor stopped, thought I had a hold of a stout root and locked her rear diff in, long story short, wasn't a root......it was the level ground at the bottom of the hill! Bent the brackets on the boxblade that the pins mount in, AND the upper brace that connects to the 3rd link! At least that is all repairable with a sledge hammer! Cannot believe the power of this little machine, able to bend 2 1/4" plate steel and a 1/4" steel brace. This thing continues to amaze me with how much weight it can lift and move effortlessly! VERY happy went with this instead of the orange one!!
    By the way ray66 at 130hrs.......this parking brake is working fine!
    2010 MF GC2610--MF60"MMM--King Kutter XB 4' rotary cutter-- 4' King Kutter XB boxblade-- Ratchet Rake-- Check that parking brake
  2. #2
    Silver Member birddog0304's Avatar
    Join Date
    Apr 2012
    Posts
    126
    Northeast TN
    John Deere/Massey Ferguson/Bobcat
    Default
    Replace the pins and take the brackets off and press them out would be better than beating on them.
  3. #3
    Elite Member
    Join Date
    Oct 2006
    Posts
    3,243
    N.E., Ohio
    GC2310, Toro Reelmaster 5100D
    Default Re: Wel it's been a while since I tore something up......
    Quote Originally Posted by Wacky View Post
    Well, you had a good long run going. LOL!
    I think since it's you, we can waive the photo's or it didn't happen rule here.
    Yes the machine is powerful. That, and they don't make stuff out of the kind of steel they used to.
  4. #4
    Platinum Member cdaigle430's Avatar
    Join Date
    May 2010
    Posts
    768
    Maine
    MF GC2410
    Did something similiar with my box blade-bent 3\4" steel like it was butter-luckily I didnt bend any parts on the tractor itself.
    2010 MF GC2410 TLB, 2006 Husqvarna YTH 2448, 2004 Honda Rincon 650, 2007 Honda Shadow Aero 750, 2006 Jeep Grand Cherokee Limited-Hemi.
  5. #5
    Join Date
    Apr 2010
    Posts
    1,074
    West Virginia
    2010 GC2610
    I brought home a 10 ton porta-power from work today and cold straightened the bends. I would have thought it would have withstood more pressure. I guess it is a good thing it did bend because it could have really tore up some expensive components. Only took 10 minutes to fix!
  6. #6
    Veteran Member irvingj's Avatar
    Join Date
    Feb 2008
    Posts
    2,171
    Etna, NH
    2005 MF GC2310 TLB
    Nice that you got off "easy" this time, Wacky!
    I let my grandson (11 yrs) drive my GC for a bit yesterday... Guess I must have told him about your saga at some point, because he mentioned he was making sure the parking brake didn't kick out on its own as he stopped on a slight incline....
    '07 GC2310 TLB, 2360 snowblower, 2325 MMM, Bro-Tek thumb, Woods GTC40-2 tiller, Woods RB-60 back blade, KK TYR-60 landscape rake, DR 60" Power Grader
    '05 VW Jetta Wgn TDI
    Numerous antique Japanese motorcycles
  7. #7
    Join Date
    Apr 2010
    Posts
    1,074
    West Virginia
    2010 GC2610
    Quote Originally Posted by irvingj View Post
    LOL. It is all in the past now. But EVERY time I park on an incline, I look through the hole in the floor to see if it is FULLY engaged, lower ALL implements and turn the wheel for the least damaging route if all else fails!!
  8. #8
    Elite Member
    Join Date
    Oct 2006
    Posts
    3,243
    N.E., Ohio
    Learn from the mistakes of others -- you can never live long enough to make them all yourself.
  9. #9
    Join Date
    Sep 2008
    Posts
    126
    Western PA
    MF GC2410 TLB w/ 60" MMM, also a 2005 Kawasaki Brute Force 750i (not a tractor but still lots of fun)
    Quote Originally Posted by ray66v View Post
    So far this summer I discovered two small issues. I bent the right-side lift arm leveling assembly (bent where the threads enter into the assembly)...I have no idea how I did this, but I was using the tiller as ballast while moving a lot of dirt w/ the FEL over some bumpy terrain (too lazy to take the tiller off since I was going to be using the tiller again) so I'm guessing it happened then. The check-chain was short enough that it wasn't banging the lift arms into the backhoe hook-up, so I'm a little puzzled...no more using the tiller as a ballast, I'll use the yard rake.
    One of the welds on the flat steel bar that connects the left and right arms of the mower deck mounting assembly broke as well. Not sure exactly what it is called...but it is the dark gray removable bracket that attaches the front of the mower deck to the tractor frame.
    Oh well, easy to fix and I have all winter to deal with it.
  10. #10
    Join Date
    Feb 2008
    Posts
    2,171
    Etna, NH
    2005 MF GC2310 TLB
    JohnnyB- same as mine on the mower deck? Here's what I did:
    Wel it's been a while since I tore something up......-dsc03401.jpgWel it's been a while since I tore something up......-dsc03402.jpgWel it's been a while since I tore something up......-dsc03403.jpg
Similar Threads
  1. TC35 A Help me figure out what I tore up.
    By Tim Stuart in forum New Holland Ag Tractors
    Last Post: 03-29-2011, 03:10 PM
  2. 1650 Oliver Tore Down
    By nwngunner in forum Parts/Repairs
    Last Post: 10-16-2010, 07:51 PM
  3. Well....I tore some stuff up today
    By MotorSeven in forum Kioti Owning/Operating
    Last Post: 11-06-2009, 08:10 AM
  4. Drive tore in half
    By Surewhynot in forum Attachments
    Last Post: 08-02-2008, 09:02 AM
  5. Tore up knee update
    By Shantycoke in forum Kubota Owning/Operating
    Last Post: 02-12-2008, 02:03 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
