newmexico
Hey Guys,
Well fall is here and here we go again with issues. I tried starting the tractor this morning and nothing....checked battery all good, made sure gear was in neutral good. Even went as far as to see if the seat thing that prevents tractor from starting was working. NOTHING. Signals work. Then thought OK check starter. Took my tester put it into the two wires both have power even when key not turned thought this is good too. Then went to put tester on actual starter motor wire no power key is off GOOD. Then turned key put tester back still no power on the wire. Now there should be that would make the starter spin and in turn start tractor. It seems like maybe the shift thing that has turtle speed and fast in the middle has neutral...where is the wire that sends that signal where ever to prevent it starting in gear. I looked down that side near the tire and there is a small yellow wire hanging there, cannot seem to see where it goes....Does anybody know what else I should do...
Thanks
Paul
Thanks
Paul
