Results 1 to 3 of 3
09-22-2012, 10:07 AM #1
- Join Date
- Jun 2006
- Posts
- 234
- Location
- Sherwood Park,Alberta,Canada
- Tractor
- 2015 Massey GC1710
3 point hitch hose and Leaky Joystick
Well, finally blew my first hose on my 2006 gc2310. It was the 3 pt hitch/backhoe hose. Looks like it wore thru by rubbing and got pinched. Will need to route it differently. Off to Goodall for a new one, except it is saturday and they are closed....
Figured I would fix the leak on the loader control as well. Hopefully just an o-ring. I see others have changed this so will tackle this at the same time. Is it a imperial o-ring or metric ???
09-23-2012, 05:23 AM #2
Re: 3 point hitch hose and Leaky Joystick
You did well to go this long! I've had to replace two on mine so far, an '07 model. First one was two years ago, IIRC. Sorry, can't help with the o-ring; haven't been there yet.
'07 GC2310 TLB, 2360 snowblower, 2325 MMM, Bro-Tek thumb, Woods GTC40-2 tiller, Woods RB-60 back blade, DR 60" Power Grader, DR Lawn & Leaf Vac
'05 VW Jetta Wgn TDI
Numerous vintage Japanese motorcycles
09-25-2012, 11:16 PM #3
- Join Date
- Jun 2006
- Posts
- 234
- Location
- Tractor
reason I had to replace a hose was due to the 3PT hitch. Happened the first month I the tractor. scuffed the rubber, finally gave out. At the same time I replaced all the rear hoses. New ones are dual braid, same size. Overkill yes, but I wanted to re-route all the rear hosesanyway, so good time to replace them. All three rear cost $90.00 and that was brand name double braid. Even got them to replace one with a 45 degree ( backhoe return hose ) as it was a very sharp bend from the tractor.
Similar Threads
Easy way to locate leaky hose?
By RobiBX2230 in forum John Deere Owning/OperatingReplies: 17Last Post: 05-15-2012, 10:42 PM -
Leaky Hose Nozzle
By Trojans1993 in forum General Lawn & GardenReplies: 0Last Post: 09-09-2011, 12:15 AM -
Backhoe hose pinch 3-point hitch
By mustbike in forum Kubota Owning/OperatingReplies: 2Last Post: 09-02-2010, 04:31 PM -
Loader leaky joystick
By Martyappleseed in forum Massey Ferguson Owning/OperatingReplies: 4Last Post: 07-28-2010, 07:46 AM -
leaky hose
By BlueCanuck in forum New Holland Owning/OperatingReplies: 3Last Post: 08-18-2008, 08:46 PM
