Results 1 to 3 of 3
  1. #1
    Gold Member KubotaToy's Avatar
    Join Date
    Nov 2011
    Posts
    413
    SE Tennessee
    Kubota B2710HSD (hers) and L45 (mine), RTV1100 (hers), Yanmar VIO80
    Default MF-50 tranmission help
    I just bought a MF-50 a few days ago and was in the process of changing all the fluids, after draining the hydraulic fluid, I decided to look in the bottom case where the pump is located and noticed two 3/8"x1 1/2" bolts and lock washers. I also found a tapper pin that is about 1/2"x1 1/2". I thought everything worked fine and am not aware of any problems. Where did these come from? I have ordered books but it will take a few days before I get them. Any help would be appreciated, I would like to verify everything is ok before I button it up and add fluid. BTW- I do not see a filter, does this model have one?
    MF-50 tranmission help-wp_000071-jpg
  2. #2
    Silver Member DaButcher's Avatar
    Join Date
    Sep 2012
    Posts
    139
    TEXAS
    MF165 & Ford 1500
    Default Re: MF-50 tranmission help
    Hydraulic filter is located behind the circular cover (with the pto lever) on the left side of the center housing
    *filter info from here Massey Ferguson MF50 Help - Yesterday's Tractor Co.
  3. #3
    Join Date
    Nov 2011
    Posts
    413
    SE Tennessee
    I have reviewed that thread, which resulted in looking for the filter. I am thinking my 50 is one of the few that did not have one.
Similar Threads
  1. 5465 tranmission problem
    By mudcity loop in forum Massey Ferguson Owning/Operating
    Last Post: 08-05-2014, 11:55 AM
  2. BX-25 tranmission strainer cleaned
    By Tachdriver in forum Kubota Owning/Operating
    Last Post: 02-23-2014, 11:14 AM
  3. Backhoe Tranmission service
    By Blackhawkranch in forum New Holland Owning/Operating
    Last Post: 09-16-2011, 09:51 AM
  4. Tranmission/ Hydraulic Fluid
    By mark4Jesus in forum Kubota Owning/Operating
    Last Post: 06-29-2005, 10:04 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
