Results 1 to 7 of 7
  1. #1
    New Member Woodsman7254's Avatar
    Join Date
    Jun 2012
    Posts
    12
    Sandstone mn
    New Massey 1529 as of 2012
    Default 1529: 50 hour service Hydraulics
    My 1529 is about ready to get its service and I am doing it myself.
    It has a loader and is sycro shuttle tranny.
    In the owners manual it talks about bleeding the Hydraulic system after changing. I am sure with a hydro tranmission that bleeding is really necessary.
    On a sycro shuttle I am assuming it may not be.
    How have you folks done when changing the Hydraulic fluid at 50 hrs? Do you bleed it when complete?
    Terry
  2. #2
    Super Member mguitas's Avatar
    Join Date
    Aug 2011
    Posts
    7,911
    Schuylkill County Pennsylvania
    Massey Ferguson 1423 Hydrostat
    Default Re: 1529: 50 hour service Hydraulics
    I did not have to bleed anything. i just lower the loader to the ground an the bucket curl. Drain the oil, an filled.
    Massey 1423, 1462 loader, wallenstein Ranch ho gx620, with subframe mount. Deere 710c
  3. #3
    Super Member WilliamBos's Avatar
    Join Date
    May 2004
    Posts
    5,061
    Innisfil, Ontario, Canada
    MF 1635 12x12 Powershuttle
    Default
    We had to bleed our powershuttle. Just open bleeder on hydraulic pump, close when no air comes out.
    Thanks,
    Will
    2017 Ram SXT 1500 Crew Cab 4x4 5.7 Hemi 6 speed auto.
  4. #4
    Join Date
    Jun 2012
    Posts
    12
    Sandstone mn
    Default
    Well did my first engine oil service this past weekend. Used Mobil 1 turbo diesel . Easier than my van to change. Good for the winter now.
  5. #5
    Join Date
    Nov 2012
    Posts
    54
    Central MA
    MF 1240
    I have a MF 1240 with a 16Fx16R synchro shuttle (not power shuttle). This is very similar to your 1529 in regards to size and power, its just a couple generations earlier. I just did my tranny/hydraulic fluid change over the summer. I simply drained and refilled, checked hydraulic operation, and fluid level. That was it, and it has been working great ever since. My factory manual doesn't make any reference to bleeding with this transmission.
  6. #6
    Join Date
    Jun 2012
    Posts
    12
    Sandstone mn
    Thanks for the input. My manual does show and tell you to bleed it but I doubt you have to in most cases. I will be changing it in the spring as I won't be putting many hours on it during the winter.
    Woodsman
  7. #7
    Join Date
    May 2004
    Posts
    5,061
    Default
    Quote Originally Posted by Woodsman7254
    Woodsman
    If it tells you to bleed ot, then do it. Air in the hydraulics is not good. For all the time it takes, do.
    Thanks,
    Will
Similar Threads
  1. 50 Hour Service
    By joeyd in forum Oil, Fuel & Lubricants
    Last Post: 08-02-2011, 06:42 PM
  2. 50 hour service
    By unclesalty in forum Bobcat Tractors
    Last Post: 06-25-2009, 07:30 PM
  3. 50 Hour Service
    By Anonymous Poster in forum John Deere Owning/Operating
    Last Post: 04-26-2003, 02:53 PM
  4. 50 Hour Service
    By akman in forum Kubota Owning/Operating
    Last Post: 07-29-2002, 12:39 PM
  5. Another 50-hour service
    By Wheeldog in forum Kubota Owning/Operating
    Last Post: 09-13-2001, 04:19 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
