Results 1 to 5 of 5
  1. #1
    New Member
    Join Date
    Apr 2012
    Posts
    9
    Weaverville, NC
    Kioti DK40HST & MF 1020
    Default 1020 parts availability?
    I've owned a 1020 gear tractor for the past twenty years and it has been the most dependable, most durable tractor that I've ever had. It was forced to do the work of a larger tractor but never complained. It is now showing it's age and needs a water pump and a few other things. It is my understanding that new parts are no longer available for this machine. Can someone confirm this information and/or give me a source for any new parts available? I have sources for used parts but don't want to install a used water pump.
  2. #2
    Elite Member
    Join Date
    Sep 2010
    Posts
    4,100
    CANADA
    Many
    Default
    You should be able to get a new pump. My grandfather put a new pump on my 1020 about 20 years ago. I would call a Massey dealer and have them check agco parts for you. Some parts aren't available new any more.
  3. #3
    Join Date
    Feb 2006
    Posts
    161
    NC
    MF1010
    Default Re: 1020 parts availability?
    Some of these tractors were sold under other brand names. The trick to it is to find out what other brands exist and go find parts for them. Your tractor is a Hinomoto with a Toyosha engine, just like my 1010. I know the 1010 was sold under other brands, and I was able to find what I needed by looking on the internet for suppliers for those tractors. My MF dealer was surprised that I was able to come up with a gear shift bushing for my tractor, and they were more than happy to help me install it.
    By the way, don't get in hurry and shift gears with much force. That bushing was plastic.
  4. #4
    Join Date
    Feb 2006
    Posts
    161
    NC
    MF1010
    There's a water pump for your tractor on ebay right now for $142.
  5. #5
    Elite Member
    Join Date
    Sep 2010
    Posts
    4,100
    CANADA
    Many
    Quote Originally Posted by lambs View Post
    I broke the shifter off on my 1020. I couldn't find one any were across Canada or the USA so I ended up chucking it in the lathe, and drilled and tapped it for a 3/8 threaded rod and drilled and tapped the same on the handle put two jam nuts between them and it works like new. Mine is case hardened steel not plastic.
Similar Threads
  1. Expected parts availability
    By msjanket in forum Kubota Buying/Pricing
    Last Post: 02-13-2012, 04:29 PM
  2. parts availability
    By dbltrbl in forum Mitsubishi/Satoh
    Last Post: 10-05-2010, 03:00 PM
  3. What's up with parts availability?
    By BigDogues in forum Kioti Owning/Operating
    Last Post: 07-18-2005, 03:05 PM
  4. Parts availability
    By twhman in forum Buying/Pricing/Comparisons
    Last Post: 11-20-2002, 01:52 PM
  5. used parts availability?
    By Anonymous Poster in forum Kubota Owning/Operating
    Last Post: 12-18-2001, 09:47 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
