Results 11 to 20 of 42
11-17-2012, 08:26 PM #11Elite Member
- Join Date
- May 2004
- Posts
- 3,795
- Location
- Innisfil, Ontario, Canada
- Tractor
- MF 1635 12x12 Powershuttle
Re: Hard to get to Oil Filter on 1526 Massey Ferguson
Thanks,
Will
I do not care if someone's net nanny is watching!! You need to stop...
11-17-2012, 08:30 PM #12Platinum Member
- Join Date
- Dec 2011
- Posts
- 522
- Location
- S/O Joplin, Missouri
- Tractor
- Massey Ferguson 1526 Hydrostat
Ok, My 1215 had the same 91 Ci motor in it but was only 17 HP. It really was a good tractor and served me for 14 years. I do like the 1526. I have had it since March and only one problem to speak of. I will have to find a end cap wrench and see if it works OK because sooner or later I'll have a hard time getting that critter off. It has that bracket in front for the side panel as well.
11-17-2012, 08:35 PM #13Veteran Member
- Join Date
- Feb 2008
- Posts
- 1,806
- Location
- Western Montana
- Tractor
- New Holland TD95D, Ford 4610 & Ferguson TO-30
I use a Craftsman Auto Adjustable Universal Oil Filter Wrench (part number 28-205230) on an hard to access oil filter on our '08 Subaru Forester. (Another dumb design. They went to this after havinga oil filter that was accessable and you could change it out in 5 minutes with no problem to one where you have to reach through a donut hole in the hot exhaust manifold after removing a plastic rock shield. DUMB, Dumb Dumb!)You use a 3/8" x 6" or longer extension and a rachet with this device.
11-17-2012, 09:59 PM #14Elite Member
- Join Date
- May 2004
- Posts
- 3,795
- Location
- Tractor
Thank you. I will look into that. I have a claw wrench similar to that, but it only works for removal.
Product PageThanks,
Will
11-18-2012, 12:11 AM #15Elite Member
- Join Date
- Apr 2012
- Posts
- 2,863
- Location
- Tennessee Vols Country
- Tractor
- My tractor is an old M... F... and red too.
Most auto parts have end cap oil filter wrenches where you use a socket ratchet to loosen the filter. Since filters are different diameters, measure yours and how many facets it has then go shopping. Service centers use an end cap type filter remover. Along time ago I used two phillips screwdriver and drove them into the filter at an angle to twist the filter loose. I now have one of those fancy self adjusting end cap wrenches that will work on any faceted top filter.
Originally Posted by radrock
Retired and enjoying life and my grandchildren -robert
"life is too short.. eat your cake first" ~rpk
My 1965 MF 135 Z145 Refurbish project
About ME
11-18-2012, 06:10 AM #16Elite Member
- Join Date
- Aug 2011
- Posts
- 2,986
- Location
- Schuylkill County Pennsylvania
- Tractor
- Massey 1423 Hydrostat
I could not use a strap wrench either. Radrock yours looks very close to my tractor.
Massey 1423, 1462 loader, wallenstein Ranch ho gx620, with subframe mount.
11-18-2012, 05:24 PM #17Platinum Member
- Join Date
- Dec 2011
- Posts
- 522
- Location
- Tractor
Here are a few more pictures, One from further away. As you can see, it is a very little filter. I changed the oil, filters, transmission/Hydrostat oil, filter and cleaned the strainer. It was a pretty nice day out today to get it done. Now I am ready for winter.
The oil filter came off by hand with no problem. I loosed it up last night while it was cold. I will have to check and try to find a cap wrench, just in case it is too tight next time. It will even be hard to use one of them. mguitas, I would say your tractor is pretty close to mine. WilliamBros had a 1523 and said it looked like his too. I used a tape measure to give you an idea how close everything is around it.
Everyone have a great week!!
11-18-2012, 05:41 PM #18Elite Member
- Join Date
- May 2004
- Posts
- 3,795
- Location
- Tractor
Yupp, that is as tight as our 1523 was. Did you keep the filter? Take it with you to try out an end cap wrench. Do you have a swivel extension? Get one of those too, it will make your life easier.
Thanks for the pics. What did you run for oil?
1635 filters...
First oil change, we cut the tie strap, and adjusted the wiring in front of the filters. I can slip a band wrench between the wires and filter with no problems. Would be kinda awkward if we had a loader though.
And here is the 1523...
It was a tough one, had to use the end cap. Had a hard enough time wiping the filter head off before installing a new filter.
What part number is your filter?? 72201898? That is the filter for the 1523.
Just an Update...
A KD 3253 end cap wrench fil the Luber Finer Filter #LFP8176. I can't remember if it fit the MF filter, but it does fit the luber finer, and the AC filter on my Sportsman. Guessing it will fit though.
http://www.luber-finer.com/catalog/parts-catalog.aspx
http://www.luber-finer.com/catalog/p...partno=LFP8176
KD 3253 cap wrench.
http://www.oreillyauto.com/site/c/de...0066&ppt=C0164Last edited by WilliamBos; 11-18-2012 at 06:47 PM.
Thanks,
Will
11-18-2012, 06:50 PM #19Platinum Member
- Join Date
- Dec 2011
- Posts
- 522
- Location
- Tractor
Thanks for the pictures. I will get another oil filter and take it with me to make sure it matches. The motor looks just the same. If you click on my pictures it will make them bigger. Dont know why yours show up bigger on the computer. One difference is that your Hydraulic line curves below the filter where mine cuts right in front of it. That line is the biggest problem. But it wasn't that bad. Thanks for the info on the wrenches. I will check it out later.
George
11-18-2012, 07:06 PM #20Elite Member
- Join Date
- May 2004
- Posts
- 3,795
- Location
- Tractor
I upload all of my pics in top quality and the original size (largest, not resized.) to my photobucket account, then copy the image link and past it with the text.
I think the end cap will be the best bet, and with a short swivel extension, you can spin it right off with no problems.Thanks,
Will
Similar Threads
1965 Massey Ferguson Air Filter Pre-Cleaner
By ArcherXC in forum Parts/RepairsReplies: 6Last Post: 11-25-2012, 12:11 AM -
Oil Massey ferguson fe 35
By kiko99 in forum Oil, Fuel & LubricantsReplies: 5Last Post: 11-24-2012, 08:34 PM -
By radrock in forum Massey Ferguson Owning/OperatingReplies: 18Last Post: 06-24-2012, 03:50 PM -
Oil & Fuel Massey Ferguson M-50 Oil
By keijus68 in forum Massey Ferguson Owning/OperatingReplies: 2Last Post: 05-01-2008, 03:24 PM -
Oil & Fuel Massey Ferguson 240 brake, Oil Filter#, and oil weight?
By wkheathjr in forum Massey Ferguson Owning/OperatingReplies: 3Last Post: 04-03-2008, 09:11 PM
