Results 1 to 10 of 26
12-19-2012, 06:35 PM #1Member
- Join Date
- Nov 2010
- Posts
- 37
- Tractor
- Massey 1529
Help! Fuel Starvation?
Hey guys- I could sure use some help. I've been browsing this forum for a couple years getting answers to all my tractor needs. I'm baffled at this point, which doesn't take a whole lot to begin with but can't seem to find an answer searching the forums.
I have a Massey Ferguson 1529 with almost 150 hours. Here lately, after running it for an hour it becomes rough running. It seems to do it more on an incline when really pulling a loud and sucking the fuel. It has occasionally done it on a decline and level ground. I have noticed while running the fuel in the fuel bowl hovers around the bottom of the filter. I'm thinking, this CAN'T be right? With the tractor OFF the fuel only fills up to about half way in the bowl. I have included pics below. The picture with fuel is before I started the engine. The second is after running the RPM's to 2500 and back down to Idle which is right at 1000.
Currently I have changed the fuel filter, inspected and cleaned air filter. Cleaned out the fuel tank. There seems to be good flow from the tank to the fuel bow. When I remove the line from the fuel bowl the fuel comes a screaming.
Any help or suggestions would be greatly appreciated.
12-19-2012, 07:38 PM #2Elite Member
- Join Date
- Aug 2008
- Posts
- 3,482
- Location
- N. of Charleston WV
- Tractor
- Kubota L4400-1 HST,FEL, 3x3 remotes, TNT. BX1500 54 mmm
Re: Help! Fuel Starvation?
Check the fuel tank cap to see if the vent is open. Also if you have a leak in the suction side fuel line you could be sucking air into the fuel bowl. check the gasket for the fuel bowl that it is sealed.
Randall
1Timothy Chapter 2:
3 For this is good and acceptable in the sight of God our Saviour;
4 Who will have all men to be saved, and to come unto the knowledge of the truth.
5 For there is one God, and one mediator between God and men, the man Christ Jesus.
12-19-2012, 07:53 PM #3Super Member
- Join Date
- Dec 2008
- Posts
- 5,267
- Location
- North Carolina
- Tractor
- Kubota BX2200
I am not used to that kind of bowl. The ones I am used to, new unfiltered fuel coming in drives other fuel upward through a screen. If it were me, I'd check the things Randall mentioned, but make sure the seal at the top of the bowl is good, and the bowl is tight. Air can go places that liquids can't, so it could be you have a leak for air, but not for liquids. I have seen that in hydraulic suction lines before.
Which is bigger?: a) $100 per month since the Big Bang or b) the US National Debt.
"write these words down GOLD WILL TAKE A $600.00 DECLINE IN THE NEXT 6 MONTHS" Grumpy Old Man 12/6/12 NY Spot price bid last via Kitco 1701.80
"Good, I'll be a buyer!" -EE_Bota 12/6/2012
12-19-2012, 08:38 PM #4Member
- Join Date
- Nov 2010
- Posts
- 37
- Tractor
- Massey 1529
Thanks Guys. I did check the fuel cap earlier. No luck. I will check over the bowl seals closely and see what happens.
12-19-2012, 09:03 PM #5Platinum Member
- Join Date
- Jul 2001
- Posts
- 910
- Location
- Central CT
- Tractor
- Struck Magnatrac 6000, Kioti DK40SE
It sounds like you might have an air leak there. Make sure the bowl gasket seals good. A little smear of grease on the gasket and the threads might help you seal it up better when you tighten it. Careful though not to overdo it on tightening. Vent the bowl to fill it all the way up with fuel and make sure the vent screw is tight and gasket is good.
"I don't do landscaping... I do battle with vegetation"
12-20-2012, 01:38 AM #6
12-20-2012, 02:16 AM #7Silver Member
- Join Date
- Mar 2012
- Posts
- 100
- Location
- Olympia, WA
- Tractor
- Kubota 3800 HST
There is a possibility that the supply line has a deteriorated lining that partially blocks fuel flow under suction but is open for gravity feed. If the supply hose is not braid covered try feeling along it's length for any soft or swollen spots. Try pinching it off with your fingers with the engine running to be sure it doesn't collapse under high suction. Air leaks at the crimped on fittings are a possibility that are almost impossible to detect. If in doubt replace the line.
Smilinjak
12-20-2012, 08:11 AM #8
Check where the fuel line goes into the tank on the bottom side. Have seen them where the line isn't long enough & the line pinches and does what you're describing. It's tough to get to and usually shows up sooner than 150 hours though.
Also, when the bowl empties, kill the machine and right away pull off the inlet line to see if fuel is flowing good. I would run the tractor & kill it with a safety switch to keep the fuel pump running without a pause in operation. It may be something floating in the tank that is partially blocking the feed line then gets released when the machine is shutdown & the suction goes away.
12-20-2012, 09:16 AM #9Member
- Join Date
- Nov 2010
- Posts
- 37
- Tractor
- Massey 1529
Thanks again for all the input. I have some running around to do this morning but hopefully can get to troubleshooting this afternoon. One last question on the fuel bowl. Should it be completely full when everything is working properly and remain full while the engine is running?
12-20-2012, 01:27 PM #10
Should be full & remain full under all conditions.
Similar Threads
Jd 320 fuel starvation?
By Frankman in forum John Deere Lawn & GardenReplies: 36Last Post: 08-07-2012, 09:30 AM -
Loss of power, fuel starvation, I think
By seacap04 in forum Kioti Owning/OperatingReplies: 8Last Post: 05-29-2012, 08:20 PM -
Oil & Fuel Fuel Starvation on Hills with MF 2660
By JWR in forum Massey Ferguson Owning/OperatingReplies: 4Last Post: 07-28-2011, 11:59 AM -
Oil & Fuel Fuel Starvation prob
By Larry_Sheehan in forum Mahindra Owning/OperatingReplies: 8Last Post: 05-01-2008, 09:51 AM -
Fuel Starvation Problem
By EastTexFrank in forum Parts/RepairsReplies: 3Last Post: 06-12-2004, 11:47 PM
