Results 1 to 2 of 2
02-11-2013, 05:00 AM #1New Member
- Join Date
- Jan 2013
- Posts
- 5
- Location
- Hindmarsh Valley, Australia
- Tractor
- 1968 MF135 for fun, MF3080 for work
3080 glass adhesive
Hi Folks,
So, here's the problem.
I opened the quaterlight on the 3080 to talk to someone and it fell off.
I've never seen glass fixed like this before so I'm looking for some pointers - I can't imagine that I'm the only one that this has happened to.
Here's what the glass fitting looks like:
The only mean of support for the front section (that opens) is what I can only describe as a bead of silicon. I'm guessing that it is something a little more specialised than that...
Any idea what is used and whether replacing it is a DIY job or do I need to drop both sections into a specialist?
02-11-2013, 12:38 PM #2Veteran Member
- Join Date
- Feb 2008
- Posts
- 1,806
- Location
- Western Montana
- Tractor
- New Holland TD95D, Ford 4610 & Ferguson TO-30
Re: 3080 glass adhesive
Most auto window installlers use a special adhesive to glue the glass to the rubber seal. You might want to check with an auto glass installer.
Similar Threads
self adhesive door seals
By footer200 in forum CustomizationReplies: 3Last Post: 12-16-2012, 11:28 PM -
adhesive advice needed
By smiley in forum Build-It YourselfReplies: 11Last Post: 12-04-2012, 04:38 PM -
Snapper 3080 drive problem
By workerian in forum SnapperReplies: 0Last Post: 06-04-2012, 01:28 PM -
Correct gasket adhesive?
By rbargeron in forum Kubota Owning/OperatingReplies: 8Last Post: 05-04-2008, 09:13 AM -
Subfloor adhesive recommendations
By 5030tinkerer in forum Rural LivingReplies: 17Last Post: 11-16-2006, 01:36 PM
