Results 1 to 2 of 2
  1. #1
    New Member
    Join Date
    Jan 2010
    Posts
    11
    southern maryland
    massey ferguson 1528
    Default 1528 hydro pedal sticking
    I did do a quick search but did not find anything. I was wandering if anyone else has had this problem. When I let off the pedal the tractor keeps going foward as the pedal slowly returns back to position, I find this very dangerous or at least destructive when doing close proximity work. I tryed greasing the fitting but no help. I used the same grease as I use on all other fittings, but was thinking maybe that grease is to thick/ tackey for this application. Any thoughts or suggestions would be great, Thanks
  2. #2
    Platinum Member radrock's Avatar
    Join Date
    Dec 2011
    Posts
    522
    S/O Joplin, Missouri
    Massey Ferguson 1526 Hydrostat
    Default
    Mine is doing the same thing on a 1526. I haven't had time to look at it real close but I also had a 1215 that did it the same thing. There is a little roller on top of the transmission I sprayed some wd40 on it and it started working good after that. Ill see if I can't find a picture of it tomorrow. I don't know how your tractor floor is but the 1215 had a cover right in the middle. Four bolts and I could access it.
Similar Threads
  1. Sticking hydro pedal
    By 94BULLITT in forum Kioti Owning/Operating
    Last Post: Yesterday, 09:27 PM
  2. sticking hydro pedal 2920
    By jimjdb in forum Kubota Owning/Operating
    Last Post: 04-09-2012, 09:51 AM
  3. TZ25DA pedal sticking
    By engineer bill in forum New Holland Owning/Operating
    Last Post: 12-13-2007, 11:02 AM
  4. reverse pedal sticking for hydro on my 955
    By Bjohn in forum John Deere Owning/Operating
    Last Post: 12-20-2004, 09:26 PM
  5. Sticking Hydro Pedal on BX.....
    By Junkman in forum Kubota Owning/Operating
    Last Post: 04-01-2004, 05:35 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
