Results 1 to 7 of 7
  1. #1
    New Member
    Join Date
    Feb 2013
    Posts
    2
    East Greenwich,RI
    Massey Ferguson 2310
    Default MF 2310
    I have a Massey Ferguson 2310 and am having problems with the backhoe. I can swing the boom to the left but it won't swing right. The outriggers go down but won't go up. I have three lins that hook up to the backhoe, marked red, blue and yellow. If I switch the lines and connect the red to blue and blue to red I can operate the backhoe, but it makes noise like a relief valve is on. Does anyone have an idea what might be happening?
  2. # ADS
    Advertisement
    Join Date
    Mar 1998
    TractorByNet.com
    Posts
    Register now to remove this ad.
  3. #2
    Silver Member Chooglin's Avatar
    Join Date
    Oct 2010
    Posts
    244
    NE Ohio
    Bolens 1468 - MF GC2310
    Default Re: MF 2310
    Not sure if yours should be the same,but this is how my 2310 backhoe is hooked up.
    1993 Bolens 1468: 38" snow blower,front blade and 42"MMM
    2007 MF GC2310 TLB: 60" MMM
  4. #3
    Veteran Member irvingj's Avatar
    Join Date
    Feb 2008
    Posts
    2,183
    Etna, NH
    2005 MF GC2310 TLB
    Default Re: MF 2310
    Rob, how did you make out? There are a number of threads on this... apparently it's not that uncommon to have the hoses incorrectly color coded. I'd also check to make sure that none of the other controls --like the 3-point hitch control-- is stuck in some position other than neutral. WBB
    '07 GC2310 TLB, 2360 snowblower, 2325 MMM, Bro-Tek thumb, Woods GTC40-2 tiller, Woods RB-60 back blade, KK TYR-60 landscape rake, DR 60" Power Grader
    '05 VW Jetta Wgn TDI
    Numerous antique Japanese motorcycles
  5. #4
    Join Date
    Oct 2010
    Posts
    244
    NE Ohio
    Default Re: MF 2310
    I am with Irv on this one,sounds like the line are not hooked up correctly.
  6. #5
    New Member
    Join Date
    Feb 2013
    Posts
    2
    East Greenwich,RI
    Default Re: MF 2310
    I didn't switch lines and the trouble started. I did it one other time and I switched the lines to return the hoe to travel position. then I switched them back and it was fine for a long time. Someone else told me it could be a faulty connector on one of the lines
  7. #6
    Elite Member
    Join Date
    Oct 2006
    Posts
    3,252
    N.E., Ohio
    GC2310, Toro Reelmaster 5100D
    Default Re: MF 2310
    Quote Originally Posted by RobV2310 View Post
    I Someone else told me it could be a faulty connector on one of the lines
    That would be a first.
    You could test that by removing the connectors and switching them to different lines. Then, see if the problem is effected.
    Just don't get confused about which line is which.
  8. #7
    Member woody49705's Avatar
    Join Date
    Mar 2008
    Posts
    37
    southwest ct.
    07' GC2310 TLB
    Default Re: MF 2310
    I am absoutley with IrvingJ---a lot of times the 3 point control lever on the right gets pushed or pulled with your right leg or knee and will definitrly affect all the other hydraulics on the machine.
    Woody
Similar Threads
  1. new use for the 2310
    By ks13 in forum Owning/Operating
    Last Post: 11-20-2006, 09:57 AM
  2. new 2310
    By Rob2310 in forum Massey Ferguson Buying/Pricing
    Last Post: 12-23-2005, 10:48 AM
  3. New GC 2310
    By Barton in forum Massey Ferguson Buying/Pricing
    Last Post: 03-07-2005, 11:47 AM
  4. USED 2310
    By LBrown59 in forum Massey Ferguson Buying/Pricing
    Last Post: 03-07-2005, 09:44 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
