Results 1 to 3 of 3
  1. #1
    New Member
    Join Date
    Nov 2012
    Posts
    6
    Center Harbor , NH
    (03) Massey gc2310
    Default 4' or 5' box scraper ??????
    I have a MF 2310 and was wondering if it had enough ambition to pull a 5' box scraper, Or does the best performance come from the 4' blade ? Can any of you give me any advise ? Thanks in advance, Don
  2. #2
    Join Date
    Feb 2012
    Posts
    777
    Staunton, VA
    John Deere 3038E
    Default Re: 4' or 5' box scraper ??????
    The ability of your CUT to pull a box blade is going to be dependent on what you are blading, and the slope involved. If you are moving light dirt on a level surface, I would think you could pull a 5 foot blade easily. If you are blading a gravel drive up a slope, the 4 foot would be better. I have a JD 3038e which is a little stronger and heavier than you tractor, and I have a 5 foot BB. I actually downsized from a 6 foot blade I had for a previous and larger tractor. But trying to pull a full box of gravel up a slope can almost bog me down. However, it works like a champ on more level ground. I can pull the blade in dry soil pretty well, but putting the rippers down will just about stop me.
    The BB is a really useful tool, but I'd go with the smaller blade for most things. It's easier on the tractor and its tires.
  3. #3
    Platinum Member JWR's Avatar
    Join Date
    Apr 2011
    Posts
    962
    So MD / WV
    MF 2660 LP, Kubota B2150, Kubota BX2200, MH Pacer, Gravely 5660, etc.
    I think you are going to be much happier with a 4' scraper. As DKC said it makes a huge difference whether you are talking soft soil and gravel versus hard baked clay. I just think the 4' is better matched to your tractor. It makes a difference how much of this work you intend to do as well. If you knew you were going to move a LOT of soft soil or loose gravel, get the 5'. I found that my scraper was great for the intended application but sits unused 99% of the time. I also found that trying to use the scraper is a major pain in the backsides if you have to get off and lower or raise the tangs for deeper/shallower digging. Most scrapers take several minutes of nuisance time to adjust the tang heights individually. Very impractical unless the work is all consistent which mine never was. I found a hydraulic top link to be a VERY big timesaver and really made the box scraper useful instead of a pain. The hydraulic top link allows you to set the tangs at some nominal medium depth and then adjust the angle of the scraper to adjust depth of digging. Thus rarely get off the tractor to mess with it. Not cheap but the hyd top link is really handy for many other things too. You'd need a free remote back there for your hydraulics.
    jwr
    MF2660 LowProfile, 7', 5' and 4' BushHogs, Orsi Articulated boom hydraulic rotary cutter, Landpride 6' finish mower, Kubota BX2200, Two Kubota B2150's, 5' snowblower, 6' blade, scraper box, Gravely 1983 w/sulky, mower & snow blower, misc. attachments. Pequea 1018 deckover trailer, half interest in Massey Harris Pacer family heirloom... and a lot of junk...
Similar Threads
  1. Box Scraper vs. Land Plane/Grader Scraper
    By EquineNetworkCO in forum Attachments
    Last Post: 06-10-2016, 11:27 PM
  2. Grading Grading scraper VS box scraper
    By Mac25 in forum Kubota Owning/Operating
    Last Post: 06-15-2011, 10:22 AM
  3. Grading Box Scraper vs Box Blade vs Middle Buster
    By Tractor_Jim_CT in forum Kubota Owning/Operating
    Last Post: 03-23-2010, 03:42 PM
  4. Drag scraper vs box scraper
    By monkeybreath in forum Attachments
    Last Post: 06-19-2003, 03:16 PM
  5. Adding box scraper instead of weight box
    By jimgerken in forum Attachments
    Last Post: 12-21-2001, 10:10 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
