Results 1 to 6 of 6
  1. #1
    New Member
    Join Date
    Apr 2013
    Posts
    4
    howell nj
    ms1030
    Default 3-point hitch hydraulic failure
    I replaced the valve control for the Ag-Tech front end loader. Now the 3-point hitch will not lift. what could be the problem? Possibly an air lock in the hydraulic system? Thanks for any input. (ms1030)
  2. #2
    Super Star Member J_J's Avatar
    Join Date
    Sep 2003
    Posts
    18,924
    JACKSONVILLE, FL
    Power-Trac 1445, KUBOTA B-9200HST
    Default Re: 3-point hitch hydraulic failure
    What brand is the tractor.
    How did you plumb the hyd.
    If everything is connected in series, and the pump is pumping, then the fluid is flowing somewhere.
    All valves have to be in series in an open center hyd system. .
    If you installed a loader valve with PB, you should have installed the PB adapter.
    The hose from the PB adapter would go back to the 3pt, and the loader OUT hose would go to tank.
    http://en.wikipedia.org/wiki/List_of..._manufacturers
    J.J.
    When I works, I works hard. When I sits and thinks, I goes to sleep.
    Git er done.
  3. #3
    New Member
    Join Date
    Apr 2013
    Posts
    4
    howell nj
    ms1030
    Thanks for your reply J-J. It is a Massey Ferguson 1030.
    what is "pb".
  4. #4
    New Member
    Join Date
    Apr 2013
    Posts
    4
    howell nj
    ms1030
    i can send a photo to your e-mail
  5. #5
    Join Date
    Sep 2003
    Posts
    18,924
    JACKSONVILLE, FL
    Quote Originally Posted by farmette View Post
    what is "pb".
    PB = Power Beyond, is a port and adapter that is available on some hyd valves to route the pump fluid downstream to the next valve.
    The PB port is capable of high pressure, whereas the OUT port is not.
    It is necessary to connect valves in series in an open center hyd system.
    J.J.
    Git er done.
  6. #6
    New Member
    Join Date
    Apr 2013
    Posts
    4
    howell nj
    ms1030
    Hi J.J., i contacted Prince, the manufacturer, and i do need a PB sleeve. ordered it from Northern Tool. Thank you very much for your help. regards, Farmette
Similar Threads
  1. 3 point hitch hydraulic problems
    By big bear 4 in forum Hydraulics
    Last Post: 03-25-2016, 11:11 PM
  2. MM 335 Hydraulic / 3 Point Hitch Issue
    By sparkhut in forum Hydraulics
    Last Post: 06-08-2015, 10:37 PM
  3. > HELP< Hydraulic 3 point hitch
    By Doug Barchard in forum Parts/Repairs
    Last Post: 10-21-2010, 09:58 PM
  4. 3-Point Hitch Deere 4720 Three Point Hitch Failure
    By TCowner in forum John Deere Owning/Operating
    Last Post: 09-06-2008, 08:21 PM
  5. Three point hitch hydraulic problem
    By Goodtimze in forum Kubota Owning/Operating
    Last Post: 04-17-2006, 09:34 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
