gezster
I have a small hydraulic leak coming from the back of the loader valve. Its coming out around the sleeve (item 17) in the diagram. I presume its coming out of the hole for items 12 and 13 and seaping out of the sleeve. This is for the up / down control portion of the valve. Its doesn't leak while raising but does leak while lowering or when stationary.
The parts list and rest of the valve can be seen on the agcopartsbook 1246 loader - hydraulics cross valve assembly (1081221M91)
Is it likely to be Item 7 the retainer seal thats causing the problem?
Thanks
Thanks
