Results 1 to 2 of 2
  1. #1
    New Member
    Join Date
    May 2013
    Posts
    2
    Hokes Bluff, Al
    360 massey ferguson, G allis chalmbers, Kubota L4600HST
    Default MF360 steering cylinder leaking
    I just replaced the seals, o-rings, etc in the right side steering cylinder which was leaking bad. After the replacement, it started leaking again after about 30 minutes of operation. On the disassembly, all parts were cleaned and appeared to be in good condition. I was careful to see that the new seals and o-rings were in place properly. The only difference I noticed was that the inner cylinder sleeve had a turned down smaller o.d. on 1 end. On disassembly, that smaller o.d. end came out last (was on the inner tractor end). The local tractor dealer gave me an exploded breakdown view which showed the turndown end to be on the outer tie-rod side. On re-assembly I installed it as it came out (not by the breakdown sheet). Does anyone know if this could cause the cylinder to be leaking again ?
    Also, does it matter which of the 2 hoses goes on which of the 2 ports on the cylinder. I think that I reinstalled them the same way they came off.
    Any help will be appreciated.
  2. #2
    Join Date
    Apr 2013
    Posts
    56
    NC
    1993 MF240 w/ 2400QT FEL
    Default Re: MF360 steering cylinder leaking
    Quote Originally Posted by pecanguy3303 View Post
    Not sure about the first part but as far as the hoses, if it is like my MF240, it does matter where the hoses go. I hooked mine up backwards by accident and it caused the steering not to work and the pump to screech.
    MF360 steering cylinder leaking-steering-jpg
Similar Threads
  1. Leaking steering cylinder, DK35
    By Anonymous Poster in forum Kioti Owning/Operating
    Last Post: 02-07-2015, 07:00 PM
  2. Gc2310 leaking steering cylinder
    By adhughes1 in forum Parts/Repairs
    Last Post: 05-08-2013, 09:12 PM
  3. 4505 Leaking Steering Cylinder
    By snakebitten in forum Mahindra Owning/Operating
    Last Post: 07-11-2010, 06:32 PM
  4. JD 4100 steering cylinder leaking
    By MARKMONKEY1 in forum Parts/Repairs
    Last Post: 05-06-2009, 11:44 PM
  5. Steering cylinder leaking
    By npaden in forum Parts/Repairs
    Last Post: 04-30-2006, 09:33 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
