Results 1 to 6 of 6
  1. #1
    New Member
    Join Date
    Jun 2013
    Posts
    1
    Mayne Island, BC, Canada
    Massey Ferguson 245
    Default MH 245 steering
    Hi all,
    1987 Massey Ferguson 245
    Steering works well turning left but to the right it hardly moves at all _sometimes_. If I try turning the steering wheel sharply right when this occurs, it _might_ respond normally. The condition just started in the last few days and is intermittent.
    I do have leaky fittings on the left steering cyclinder but I top up the oil level in the pump before use.
    Is this steering pump? or other?
    I have an industrial FE loader on board but am using the tractor for mowing with a John Woods 6' horizontal brush cutter.
    Thanks,
    River
  2. #2
    New Member
    Join Date
    Jun 2014
    Posts
    3
    portland
    Massey Ferguson 245
    Default Re: MH 245 steering
    Quote Originally Posted by RiverJudd View Post
    Hi all,
    Thanks,
    River
    I am having this exact issue with turning right on my MF 245. What did you ever find out?
  3. #3
    Member
    Join Date
    Apr 2013
    Posts
    49
    NC
    1993 MF240 w/ 2400QT FEL
    So you have two steering cylinders?
    It depends how fast the one cylinder is leaking. If it is a steady stream, that could be your issue. If you wanted to rebuild the cylinders it is not that difficult to do with basic hand tools. And to do both sides it is less than $60 in parts.
    MH 245 steering-photo-1-jpgMH 245 steering-photo-2-jpgMH 245 steering-photo-3-jpgMH 245 steering-photo-4-jpgMH 245 steering-photo-5-jpg
  4. #4
    New Member
    Join Date
    Jun 2014
    Posts
    3
    portland
    Massey Ferguson 245
    I have only one steering cylinder. There are no external visible leaks. Yesterday I reversed the hoses on the cylinder, and the problem remained when turning the wheels to the right (which was turning left on the steering wheel).
    Here is my theory, please tell me if it makes sense:
    With the single steering cylinder, when you turn left, the piston is expanding. When you turn right, it's contracting. An expanding piston has the entire surface area of the Inner Diameter of the cylinder to push against. When a piston contracts, the surface area that the hydraulic fluid can push against equals the Inner Diameter of the cylinder minus the outer diameter of the piston rod. Meaning that when turning right, the fluid has less surface area to push against, and hence needs greater pressure to exert the same amount of force as when turning left.
    So I think the problem is a weak power steering pump. But I can definitely see merit in your theory for the cylinder seals. The same principle I described above would apply.
  5. #5
    Member
    Join Date
    Apr 2013
    Posts
    49
    NC
    There is also a filter inside the pump that can be cleaned prior to replacing the pump. If it was a clogged filter I would think you would have issues with both left and right.
    When you do figure it out, be sure to let us know. Good luck.
  6. #6
    New Member
    Join Date
    Jun 2014
    Posts
    3
    portland
    Massey Ferguson 245
    Replacing the pump did not fix the problem. I am currently working on replacing the seals in the steering cylinder.
Similar Threads
  1. Replies: 6
    Last Post: 11-09-2017, 10:08 AM
  2. TO35 Power Steering seal leak at steering column
    By imageshift in forum Parts/Repairs
    Last Post: 06-15-2017, 10:01 PM
  3. Oil & Fuel MF 245 part leaks & what is it???????
    By Scffle in forum Massey Ferguson Owning/Operating
    Last Post: 05-17-2013, 09:22 PM
  4. Replies: 5
    Last Post: 01-30-2013, 01:54 PM
  5. Replies: 3
    Last Post: 07-04-2012, 01:09 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
