TractorEnvy
I'm trying to find a rear blade for my GC2410 which has angle, tilt, and offset capability. I need the tilt function for cleaning out ditches. I realize the limited lift height on the GC 3-pt will make the use of a tilted blade a bit dicey but, even if it's necessary to dismount and adjust the tilt after each pass, such a blade would be useful to me.
When I bought my tractor the dealer sold me a Bush Hog 6' rear blade, insisted that it would work just fine with the GC. But after only about 10 minutes of trying to use the blade it was obvious that it wouldn't lift high enough to avoid scraping off every high spot in my yard:thumbdown: The dealer took the blade back and ever since then I've been searching for a compatible blade. Just came across the Cammond Industries site last week and I see they have a small rear blade with the features I'd like to have. Awaiting a report back from the distributor as to whether their blade is suitable for the GC. I'm thinking the moldboard, at 13 inches, may be too high for adequate clearance.
Has anyone used the Cammond 5' rear blade with a GC series tractor and, if so, does it work well for you? Anyone have a rear blade with angle, tilt, and offset from a different manufacturer which works for you on the GC series?
Thx!
Thx!
