Venturabass
First the background. I have a Massey Ferguson 1240 compact tractor and I'm having some fuel filter issues. The inlet fuel line goes into the filter head with a metal 90 degree fitting. The last time I changed the filter I noticed this inlet fitting was able to rotate. When I put it all back together the inlet fitting popped out of the filter head and fuel started pouring everywhere.
The inlet fitting looks like it should have some sort of o-rings but it doesn't, and my dealer told me it doesn't. It's not suppose to rotate in the head from what I understand. Since this issue I've just zip-tied the inlet fuel line so the fitting doesn't pop out of the filter head. It doesn't leak, but it slowly wets all my fuel lines and everything so it's time to fix the issue.
I finally was able to track down a used fuel filter assembly from a tractor salvage yard. It came off a Massey Ferguson 1260, and is the same part number: 3756671M91. However the inlet 90 degree fitting points upwards, where as on mine it points downward. The fuel line runs horizontal to the front of the tractor along the frame, and then turns upward to connect to my existing filter. All the diagrams in my factory repair manuals also show this fitting pointing downward.
I'm rather confused why this filter assembly off a 1260 (almost the same tractor) would have the fitting pointing upward, especially when its the same part number as what I have. So if there is anyone out there with a model 1240, 1250, or especially a 1260, could the check what the orientation of the inlet 90 degree fitting is to their fuel filter?
Also does anyone have any experience with this? Is there a way to rotate the fitting without ruining the seal?
