bumperm
As SPYDERLK says, the numbers on your 3 point control lever are for reference (when the 3 point is "positioning" better, and not "inching" not so better). It's common to have a sliding lock plate that your can move up so that the lever will not go down beyond a set position while mowing etc. This allows you to lift the mower deck and then immediately put it back down to the precise set position again without hassle.
There is another way to accomplish this, and that it to install a couple of limit chains on your 3 point lift arms. These chains are then adjusted to allow the mower deck from to only go down to the desired level when you drop the 3 point. For top and tilt equipped tractors, this also mitigates any problem you might have with leak down.
