I sold a camper trailer, in which I had put in all LED bulbs. I reinstalled the original 921/1156 bulbs when it sold. Now I have about 40 LED bulbs setting around to play with. All different kinds bought over a one year period. I did buy the second set at Advance Auto and do like them much better. They are very much brighter than the original incandescent bulbs, and brighter than the older LED bulbs I had on hand. In person, I think they are worth the money. The new bulbs are 2.5 watts where as each incandescent bulb was 13 watts. Net result is 10 watts vs 52 watts. I am not sure what the watts were on the first set of LED's, but 1.5 watts comes to mind.Rider, so if I understand this correctly, you bought and installed 1 set of new led bulbs for your front headlights but then a day or so later you bought a different brand/type and installed those instead ?
1. Could you take back the 1st ones. ?
2. What caused you to try the second set so soon after getting the 1st set ?
3. Is the 2nd set preferred over the 1st set. ?
4. $25 bucks a bulb for the 2nd set . . Not a cheap experiment Is there a difference in wattage draw between the 1st set and 2nd set of led bulbs?
Thanks.
921s are what came in the tractor. They are common as RV and travel trailer interior lights. Also reverse lights. The mission is to find a better replacement bulb which will put out more light without producing more heat and staying under the original wattage as to not over load the system of four bulbs. The extra bright white LED bulbs fit the bill.Those aren't exactly headlight bulbs. :confused2: Probably used to keep you from running into the garage door at night. They're commonly used for automotive brake lights.
