Stlmatt
Well It's been awhile since my last post, but wanted to update what's been going on with this tractor.
I bought a New GC1720TLB in April of 2015, It has the DL95 loader and CB65 hoe, 48"finish mower. Paid 18K
Current hours 223
So far this machine has spent over 3 months of its life in the shop, I've taken it in 4 times myself and several times I was able to get the dealer to come get it a few times. (had to really ***** and get factory involved to do so)
My first issue was the linkage for the loader control arm came apart and the arm just flopped around, I had to fix it in the field as loader was set on the ground when it broke.
Next I had several hydro leaks and the unit had NO power....the dealer had to come get it twice, they ended up replacing the hydro pump the second trip.
I was so unhappy with the first dealer the factory service rep transferred my warranty to another dealer......something to think about it when buying new....how far is the dealer???, I live just outside the St.Louis area and my closest dealer is still an hour drive:-( Not a big deal unless you have the issues I have had.......I have spent over 12 hours driving and several days off work taking this POS in and or picking it up.
Anyway back to the list of issues.
High range on my machine is worthless, its only good for flat level ground.......I have to mow (48" finish mower) in Low range because it wont go up a small hill in high range.....Dealer told me this just how it is, Live with it.....my friends JD1025 goes anywhere it wants in high range:-(
I can't count how many bolts and things I have tightened/replaced on this machine, every hydro QD/hose has had to be tightened....as if they were installed hand tight...WTF!
I have had the throttle cable replaced once and its now being replaced again because it gets locked up/stiff and wont move without feeling like you are going to rip the lever off....yes I tried lubing it.
The bolt that secures the lower three point hitch arm pin in place fell out, causing the pin for the arms to slide out enough that the left arm was flopping around (another must fix yourself....because I was using it at the time)
Now the latest major issue. I was using the loader to mover some dirt when I heard a loud POP and the tractor almost tipped over, I had a decent amount of weight in the bucket (but it was NOT overloaded or even close to Max weight) the weld from the LH loader support (the part that mounts to the frame of the tractor) broke and the loader tilted causing the tractor to feel unstable....I dropped the bucket ASAP when it happened and I think that's what saved me.
You can see in the picture that its a faulty Weld, it was really one welded in one small spot, 95% of the weld was never really welded.
I couldn't believe my eyes when I looked at it......WHAT a crappy job! So time to load up and make another 2.5 hours round trip to the dealer........when I got there he agreed and was like what the ****!!!!! that's horrible, said I should have it back in a week, they are also going to replace the throttle cable, order the correct bolt for the three point arm pin as well as service the machine.
That's was on 5-23-17, I called today and they are still waiting on warranty approval for the broken weld.......when I asked why is it taking so long, I was told here is the number to AGCO call them myself.....so I did, and I'm still waiting on a return call.
I am amazed at the lack of customer support for this POS, I don't know about most dealers but the ones I've been to are small rural dealer that have little inventory and don't seem to know a thing about these GC1700's.......again I should have went with a JD or Kubota....at least they have dealers close and seem to stock a lot of equipment and parts.
I will say the CB65 Hoe has been great and I do think its better than the other brands......but then again I don't use the hoe very often, I bought a NEW tractor because I didn't want to work on a used one.....well so much for that. If I could have bought this unit for half the price it still wouldn't be a good value.......considering the time I've spent working on it and time in for repairs....I'm sure I'm leaving out a few other issues, but my mind is so mad about it I cant think.
Thoughts? Stl Matt
Current hours 223
Thoughts? Stl Matt
