LeTempt
- Joined
- Nov 8, 2008
- Messages
- 54
- Location
- Alabama
- Tractor
- John Deere 5065E Cab and John Deere 316GR skid steer
Purchased a 2018 1742 and picked up the operators manual for the tractor the other day. The dealer ordered a 3rd function kit and block heater for me and they are going to deliver the tractor once they are installed, hopefully in a couple days.
Got confused when reading through the lubrication and maintenance charts in chapter 4. Let me give you an example with the engine oil and filter. In table 4.1.2 it tells you to change the engine oil and filter at 50 hours and then at 100 hours, no problem with that. Clearly they want you to change the engine oil and filter a couple times early on as the engine is getting broken in. Then if you go to table 4.1.1 it tells you to change the engine oil and filter at 200 hours and 500 hours. This makes no sense to me. If I were to try to make any sense of this It would sort of appear that once I hit 500 hours that the oil change interval is every 300 hours? The chart just goes to 500 hours. If they would just not have said to change the engine oil at 500 hours it would have been more clear and I would have said the oil change interval was every 200 or 300 hours after the initial 50 and 100 hour changes specified in 4.1.2. It does not say it is an interval chart, so you could easily say the engine oil and filter should be changed at 50, 100, 200, and 500 hours....with a 300 hour interval once you hit 500 hours.
Same question for the transmission/hydraulic fluid. Table 4.1.2 says to change the fluid and filter at 50 hours. Table 4.1.1 says to do it at 300 hours. Is that 300 + 50 or 300 total? Would make more sense if they said to replace it at 50 hours for the initial service and then XXX hours thereafter to avoid any confusion. It would even make more sense if everything was covered in 1 table that started at the first 50 hour service and went to say 3000 hours (longest service interval).
I will just probably simplify things and change the engine oil every 200 hours or annually and the transmission/hydraulic fluid every 300 hours. Sort of surprised they do not tell you to change the oil every XXX hours or annually like my JD 5065E. It would also be nice if the services would come due at the same time.
Any advice or assistance with clarifying this would be appreciated.
Jeff
Jeff
