Results 1 to 8 of 8
  1. #1
    Silver Member mark4Jesus's Avatar
    Join Date
    May 2005
    Posts
    223
    Sale Creek, TN
    Massey Ferguson 1433v, 8X8 Synchro Shuttle trans.
    Default 1433 Front Wheels
    I was looking at the tractor the other day and noticed that the front wheels do not have the same angle on them, i.e. top a little wider than the bottom. I think this is called the "toe in"? Looking at the front of the tractor, the right wheel has more toe in, the angle from veritcal is greater that the left wheel. This is the wheel that the power steering actuator connects to. It doesn't look as though there is a way to adjust this angle. Is it normal for the toe in to be different between the front wheels?
    I'll try to get a picture of what I'm talking about. Not sure that I have explained it very well.
    Massey Ferguson 1433v, Bush Hog SQ600
  2. #2
    Super Member JerryG's Avatar
    Join Date
    Apr 2000
    Posts
    7,235
    Northwest Arkansas
    MF 1440-4 PowerShuttle
    Default Re: 1433 Front Wheels
    Quote Originally Posted by mark4Jesus
    It has positive camber. Toe is how close the tire is front to back. I would think that the difference would almost have to be an optical illusion. Both sides should be the same. There is no way to adjust this angle.
  3. #3
    Join Date
    Oct 2006
    Posts
    1,212
    Mine (1433) look somewhat like that.
    but when you put weight on it (FEL), they seem to look straight
    the tires wear evenly
    I don't lose any sleep over it.
  4. #4
    Gold Member MrSteve's Avatar
    Join Date
    Sep 2005
    Posts
    480
    Middleport, NY
    John Deere 2025R
    I know what you are looking at and yes they are a bit out at the top then the bottom, but don't worry this is very normal on "most" tractors. This way when making left or right turns the wheel will straighten out and make turner a bit easier and when going straight, this setup makes the front wheels dig in a "bit" for traction... Remember 99.9% of the time you are in dirt not pavement like you would be in a car, with that said, think about the old cars\truck with solid straight axles they were the same way as the axle in your tractor, but that setup was for a "give and take" for load on the front and steering.
  5. #5
    Join Date
    May 2005
    Posts
    223
    Sale Creek, TN
    Sometimes when I look at it I think that it is off and other times they look the same. I think it may be, as Jerry said, an optical illusion. As I think about it it may depend on when it is on and off the concrete drive. I'll try to take photo tomorrow. Thanks for the replies.
  6. #6
    Veteran Member Nasty135's Avatar
    Join Date
    Jan 2004
    Posts
    1,423
    Southern Md.
    massey ferguson 135/1433v
    Mark, Your optical "conclusion" is perhaps enhanced by the possibility that your may not be looking at your tractor on a perfectly level spot.. Have you checked your air pressure?
    Hope I can sleep tonight....
  7. #7
    Join Date
    May 2005
    Posts
    223
    Sale Creek, TN
    Nasty,
    That is a very good question to which the answer is no. I will check that this evening. A friend of mine bought a Mahindra 6000 4WD with a FEL and BH that I have to go touch first!
  8. #8
    Super Member scott_vt's Avatar
    Join Date
    Oct 2004
    Posts
    5,145
    east wells,vt
    1986 MF 1040, 1942 Farmall A, 1949 Farmall Super A
    Afternoon Mark,
    As Jerry stated, toe in is the amount the front tires are turned in towards each other. This is usually no more than a 1/4" and keeps the front tires from wondering while going straight.
    What I think your talking about is the camber of the tire in relation to the ground. You can actually see what this by parking the tractor on a level concrete floor and use a carpenters square next to the side of the tire or rim.
    As Jerry stated earlier this cannot be changed.
    scotty
    ,,,course,,it is gas,and gas is,,well,gas,,so,,but it kills the @#$$ oughta them yellow jackets,,,thingy
    http://www.tractorbynet.com/content/...onth-scott_vt/
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
