Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
  1. #11
    Member
    Join Date
    Sep 2007
    Posts
    35
    Arizona
    Oliver 70, Yanmar 1500D, John Deere 301a, Kubota B3030
    Default Re: Steering gear sloppy on Mit MT372
    Is that block heater plug a Hubbell twist lock?
    It's available from Newark and a few other suppliers.
    The Newark stock number for the female is 81F2907.
    Their catalog is US - Electronic Components Distributor | Newark.com
    Attached Images Attached Images
  2. #12
    Gold Member BTackett's Avatar
    Join Date
    Jan 2008
    Posts
    283
    Knoxville, Tn
    No, its not a twist lock. It is a 2 prong plug in type. The plug is actually curved kinda like a C. I found a replacement at Jeg's but I am not going to pay their $11.95 handling fee on a $12 order.
    Bill
  3. #13
    Join Date
    Apr 2000
    Posts
    1,719
    Dixon, Il
    ford 9700, tw30, massey, jd2030 jd4010, yanmar F60d, ym330d, ym276d,ym226d,ym186d, ym2000, ym155
    Adjusting the sector shaft will not fix your problem. You have at the least a bad bearing & possibly a bad steering shaft assembly. If you have just a bad bearing & adjust it to remove the slop, you'll eventually damage the steering shaft assembly( ball/nut assembly). I rebuild steering boxes. Some of the Mitsubishi parts are fairly expensive, but I can sometimes source them from other brands.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
