Results 1 to 2 of 2
  1. #1
    New Member
    Join Date
    Apr 2010
    Posts
    3
    Default Satoh S373D 3pt problems
    Hello all - I just purchased a Satoh S373D that's in need of some TLC and the first issue that I'm having is a 3pt that needs some adjustment. It goes up and down just fine but nothing holds it in the "up" position. The weight of the lever brings the 3pt back down so I have to hold the lever in the center so I can keep the attachment up. I've adjusted the rod with the two springs on it so the lever has tension but then I lose some of the travel distance. The one picture I found online only had one spring but it was for a different tractor model so I'm not sure if that is the way mine should be. Any help or a diagram would be appreciated. Where could I find a manual for this tractor?
    Also, am I correct in thinking that this tractor doesn't have any down pressure for the 3pt?
    Thanks.
  2. #2
    mit
    mit is offline
    Gold Member
    Join Date
    May 2007
    Posts
    471
    Default Re: Satoh S373D 3pt problems
    you are correct in thinking that the 3 point hitch has no down pressure.the down pressure is weight or gravity.you will have to find some way to secure that lever.call valley power the guys there may be able to get you the fasteners.
Similar Threads
  1. Satoh S650G Maintenance Parts Info
    By jgreen302 in forum Mitsubishi/Satoh
    Last Post: 10-21-2011, 02:33 PM
  2. Satoh Beaver Implements
    By Hyzercreek in forum Mitsubishi/Satoh
    Last Post: 06-14-2009, 09:01 AM
  3. 3-Point Hitch 3pt Hitch Implements
    By Hugh Jazz in forum Mitsubishi/Satoh
    Last Post: 12-24-2008, 08:22 PM
  4. 3pt Hitch will not raise on Satoh ST1440
    By Sweetheart in forum Hydraulics
    Last Post: 08-17-2008, 11:14 PM
  5. 2305 problems...Dealer and mechanical (long...sorry)
    By impnst8 in forum John Deere Owning/Operating
    Last Post: 07-25-2006, 09:38 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
