Page 5 of 5 FirstFirst ... 2345
Results 41 to 47 of 47
  1. #41
    Member
    Join Date
    Feb 2010
    Posts
    36
    Default Re: need help finding a HYD tap adapter for a Satoh Beaver
    Duwem, thanks for the tip. Called Valley this morning and YES, they do have a local machinist who is manufacturing them on request. It should be here within a couple/three weeks.
    Vvm
  2. #42
    Join Date
    Nov 2011
    Posts
    178
    John Deere Garden Tractors
    What do they charge?
    There is also an option to tap into the area right below the knob that controls how fast the 3pt goes down. If I recall from the manual, if you have the 3pt lever in the down position (maybe it was up??) you get flow out of there, and would just return it to the tank like via the fill plug area near the gearshift. You would loose 3pt functionality though with that setup.
    Mitsubishi/ Satoh S-373D and TWO MT372 Compact Tractors
    John Deere 70, RF110, 332, 345, and 420 Garden Tractors, Struck MD45 Dozer
  3. #43
    Member
    Join Date
    Feb 2010
    Posts
    36
    Quote Originally Posted by duwem View Post
    Valley Power charges $175 for the adapter plate. It has one inlet and one outlet port. For this application, I'll need the use of my three point arms for a landscape rake, so the other option you mention wouldn't apply. My dozer blade has one cylinder for up/down and two cylinders for right/left angle. Control valves will be mounted on a pedestal adjacent to the throttle lever, same location as for a FEL.
    Vvm.
  4. #44
    Elite Member
    Join Date
    Aug 2004
    Posts
    2,706
    North of Mtl,Que,Can (Ste Adele)
    MT180D
    Quote Originally Posted by Freakingstang View Post
    This is the one I was sent. They assured me numerous times that it would work but the bolt hole pattern is about twice the diameter. Any idea what tractor this one fits?
    I recognize that one as being what fits a MT180D (and 160D)
  5. #45
    New Member turkey2731's Avatar
    Join Date
    Nov 2007
    Posts
    15
    I did this I think 4 years ago and had no problems.
    need help finding a HYD tap adapter for a Satoh Beaver-hydraulic-hose-2.jpgneed help finding a HYD tap adapter for a Satoh Beaver-hydraulic-hose.jpgneed help finding a HYD tap adapter for a Satoh Beaver-hydraulic-valve-setup.jpg
  6. #46
    Join Date
    Nov 2007
    Posts
    15
    Things that might be useful or at least interesting.
    need help finding a HYD tap adapter for a Satoh Beaver-jse_beaver_s370_-filters-.jpgneed help finding a HYD tap adapter for a Satoh Beaver-p9260006.jpgneed help finding a HYD tap adapter for a Satoh Beaver-pa040003.jpgneed help finding a HYD tap adapter for a Satoh Beaver-pa170002a.jpg
  7. #47
    Join Date
    Nov 2011
    Posts
    178
    Here is the adaptor I'm assuming is factory on my MT372.
    Attached Thumbnails Attached Thumbnails need help finding a HYD tap adapter for a Satoh Beaver-adaptor.jpg
Similar Threads
  1. Satoh S370 Little Beaver Hydraulics Questions
    By billchap in forum Hydraulics
    Last Post: 05-28-2012, 06:05 PM
  2. Mowing Satoh Beaver S370 Belly Mount Mower
    By Hugh Jazz in forum Mitsubishi/Satoh
    Last Post: 02-24-2012, 10:36 AM
  3. Satoh Beaver Front End Loader
    By dodgeram945 in forum Mitsubishi/Satoh
    Last Post: 04-21-2010, 11:28 PM
  4. Satoh Beaver Implements
    By Hyzercreek in forum Mitsubishi/Satoh
    Last Post: 06-14-2009, 09:01 AM
  5. Satoh Beaver 370
    By ironmike in forum Mitsubishi/Satoh
    Last Post: 09-13-2003, 05:29 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
