Results 1 to 8 of 8
  1. #1
    Member tommypaul's Avatar
    Join Date
    Mar 2009
    Posts
    25
    Default satoh s370d hydro-oil fill
    hi guys well got my parts and i'm getting ready to put my tractor back together after the new clutch and refurbish project. ok i have the service manaul and it tells to fill hydro-oil to the bolt on the side. i'm wondering if there is something more/or if there should be a little more oil added for the loader? if so how much? thx for your helpps here a few picturessatoh s370d hydro-oil fill-001-large-.jpgsatoh s370d hydro-oil fill-002-large-.jpgsatoh s370d hydro-oil fill-005-large-.jpgsatoh s370d hydro-oil fill-004-large-.jpgsatoh s370d hydro-oil fill-006-large-.jpg
  2. #2
    Join Date
    Sep 2002
    Posts
    1,298
    Mt. Ulla, NC
    Satoh S-470D, Mitubishi FD 1450D
    Default Re: satoh s370d hydro-oil fill
    Here Satoh Parts is a picture from Valley Power showing the fill plug. I think it is on the left side where your heel would be on the running board.
  3. #3
    Platinum Member techwrtr2's Avatar
    Join Date
    Nov 2007
    Posts
    593
    Alabama PA
    Which one?
    I think if I were refilling my system after mostly draining it, with all cylinders in their retracted position, I'd fill to normal level. Fire the tractor up and cycle the cylinders in/out several times and after retracting them shut the tractor down and check it again adding as needed.
    I don't recall there being any mention of overfilling on my tractor, but most of the literature we had on it is long gone.
    Where did you get the service manual and how much?
    I like to play in the dirt....
    Satoh Beaver w/Blackhawk loader & hoe.
    JD855 w/stuff.
  4. #4
    Join Date
    Mar 2009
    Posts
    25
    thx oliver28472 the question is. should'nt more oil be add because when the loader calls for hrdro-oil would it not leave the tranmisson low? so would't it need a little more oil then just a stock tractor? thx tommy
  5. #5
    Join Date
    Mar 2009
    Posts
    25
    Quote Originally Posted by techwrtr2 View Post
    thx for your reply got my manuals from jensale got a servive & operator;s manual
  6. #6
    Join Date
    Sep 2002
    Posts
    1,298
    Mt. Ulla, NC
    I agree with techwrtr2
  7. #7
    Join Date
    Nov 2007
    Posts
    593
    Alabama PA
    Which one?
    Quote Originally Posted by tommypaul View Post
    Others probably can answer with greater authority, but I do not think the cylinders will use so much fluid when totally extended that you are in a dangerous position. Particularly since you don't run all day long with the loader arms all the way up and the bucket dumped. If you do, I suggest you consider other issues first.
    JD855 w/stuff.
  8. #8
    Join Date
    Nov 2007
    Posts
    593
    Alabama PA
    Which one?
    I think I've seen them on eBay.
    I'd love it if they sold them as a PDF.
    JD855 w/stuff.
Similar Threads
  1. New Satoh S370D owner
    By Freakingstang in forum Mitsubishi/Satoh
    Last Post: 12-25-2011, 05:24 PM
  2. How to turn off Satoh S370D
    By mddrcefish in forum Owning/Operating
    Last Post: 10-12-2010, 03:19 AM
  3. Satoh S370D Tractor
    By Farmers Daughter in forum Mitsubishi/Satoh
    Last Post: 05-02-2008, 04:50 PM
  4. Satoh S370d Beaver
    By jdl in forum Mitsubishi/Satoh
    Last Post: 01-12-2006, 12:41 AM
  5. Satoh S370D
    By tacoma1 in forum Mitsubishi/Satoh
    Last Post: 06-25-2005, 11:50 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
