Page 5 of 5 FirstFirst ... 2345
Results 41 to 49 of 49
  1. #41
    Gold Member Freakingstang's Avatar
    Join Date
    Nov 2011
    Posts
    370
    Berlin Center Ohio
    Satoh beaver s370d
    Default Re: New 370D owner
    Did you say work bench? Lmao
    Kinda hard to use the vise though...
    1999 Kubota G1900 HST B2750 Dozer blade
    Satoh S370D Beaver 4x4, 2 cyl Mitsu diesel, Custom FEL with Hay forks
    Woods RB60, KK 48" BB, Woods RM59 CCW, 48" Brinly disc, Farmhand Carryall, AB 1 btm plow, AB HH/trailer mover
    Angry Beaver Front End Loader build thread- Click Here
  2. #42
    Member
    Join Date
    Jun 2012
    Posts
    31
    Barnstead, New Hampshire
    Mitsubishi Satoh Beaver S370D
    I got to try out the snowplow blade I cobbled together, It works perfect. It think the blade came off an older Lawn tractor it's very heavily built. I can't believe how easily this tractor pushes large amounts of snow. I will definitely do a couple of modifications in the Spring. Hydraulic angle for the blade and widen the blade. I have a question about the differential lock by the foot board of the tractor. I was just reading the owners manual and it says that it is on a spring and you can lock and unlock the diff. The one on my tractor is laying right on the floorboard and I have tried to lift it up out of curiosity before and it wouldn't budge (I had no idea what it was for until a few minutes ago). If the diff is locked all the time is this a problem? I have never noticed any problems with the operation of the tractor.
    New 370D owner-img_20130129_162857.jpgNew 370D owner-img_20130129_162923.jpgNew 370D owner-img_20130129_162932.jpg
  3. #43
    Join Date
    Sep 2002
    Posts
    1,300
    Mt. Ulla, NC
    Satoh S-470D, Mitubishi FD 1450D
    You probably ought to get some PB Blaster or other good penetrating oil and get that loosened up. I would think it would be hard on the differential to be locked all the time. I've heard of this with others too. My Mitsubishi 1450 is similar to the 373 and the 470 as well except for the 470 having a larger engine. When I got the 1450, it was froze up the same way. I think I was able to take a hammer and gently tap on the back side of that little pedal to make it pivot back up. I used some PB.
  4. #44
    Gold Member Ilikeurtractor's Avatar
    Join Date
    May 2011
    Posts
    373
    Iseki TX1300F/TX1500/ TX2160F/TS2220F/ Satoh S373D
    Chances are your differential is not in the locked position. If it was it would be very noticable going around corners to the point that you'll skid one of the rear tires and it will be very difficult to steer especially on concrete or pavement. I had the same problem with mine and once I freed it up where it goes into the transmission case all was well.
    One nice thing about being average is you're not alone.
  5. #45
    Join Date
    Nov 2011
    Posts
    179
    John Deere Garden Tractors
    Diff lock foot pedal is a little deceptive.
    Make a turn, if the inner wheel is skidding/pushing, the diff lock is stuck on.
    If its not, stop, press down on the foot pedal, and repeat. May stay locked in even if you let off the pedal till you stop moving or change directions as it will tend to stay engaged when your putting power though the rear wheels.
    Mitsubishi/ Satoh S-373D and TWO MT372 Compact Tractors
    John Deere 70, RF110, 332, 345, and 420 Garden Tractors, Struck MD45 Dozer
  6. #46
    Member caferacermike's Avatar
    Join Date
    Dec 2012
    Posts
    36
    Austin TX
    Satoh Beaver S370, Ducati Paul Smart Sport Classic 1000DS, Ducati S4RS Tricolore Monster, Norton Commando
    Demigod, mine is the exact same way. I pay it no attention.
    I use my right/left brakes all the time when I'm shredding. I figure it wouldn't turn right if it were locked into position.
  7. #47
    New Member
    Join Date
    Feb 2013
    Posts
    4
    rutherfordton,nc
    satoh s370d
    Just got a 370d myself, mine was stuck engauged also. I sprayed the pedal and lever with PB, took the pedal off. and used a hamer and pry bar to move back and forth till it loosened up. Well worth the 15 min to fix. Its alot easier to turn in and out of tight places now.
  8. #48
    Member
    Join Date
    Jun 2012
    Posts
    31
    Thanks for all the info. It must not be engaged then. I will see about freeing it up and making it functional cuz' I had to tow my snowmobile up from the backyard through some deep snow and I had to keep pulling myself forward with the plow blade. If I had diff lock I don't think I would have been getting stuck. Thanks again.
  9. #49
    Join Date
    May 2011
    Posts
    373
    Yes, you'll want a functional differential lock. I wish these tractors came with front differntial lock sometimes. Occasionally you'll wind up with the tractor "teetering" on the ground where one tire on the front and rear are basically in the air. Differential lock is a life-saver then as well as in other circumstances.
Similar Threads
  1. Price Check S-370D
    By jfurman in forum Mitsubishi/Satoh
    Last Post: 04-24-2011, 09:29 PM
  2. Beaver S-370D
    By mariner1 in forum Mitsubishi/Satoh
    Last Post: 01-01-2011, 04:06 AM
  3. 370d clutch
    By treecutter in forum Mitsubishi/Satoh
    Last Post: 05-19-2010, 06:51 AM
  4. Mitsubishi S-370D
    Last Post: 12-20-2005, 08:57 PM
  5. MITSUBISHI S-370D
    By ZZEKE in forum Mitsubishi/Satoh
    Last Post: 09-28-2005, 01:21 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
