Page 1 of 2 12 LastLast
Results 1 to 10 of 13
  1. #1
    Gold Member ihuntbear's Avatar
    Join Date
    Jan 2010
    Posts
    430
    new brunswick, canada
    2015 tym T554 and 1999 Kobota m4700
    Default no start
    have a satou 650 that wont start..think its the float in the carb..anybody know how to set one..gas is pouring out the tube on top of the carb and the float isnt stuck..think its called air tube for fuel bowl...also having problem with intermitting fire..sometimes it has it and some times it doesnt..think its in the voltage regulator..think im going to put a gm alternator on it and bypass everything else...also starter is getting weak..does anybody know what starter will fit
  2. #2
    Member
    Join Date
    Feb 2010
    Posts
    47
    Redmond,OR
    S-650g
    Default Re: no start
    These copies from the book have some helpful information in regards to setting the float. Intermittent spark sounds like bad ground, plug/coil wires, condenser, points, or cap but not so much like regulator/alternator unless your system isn't charging at all. Numbers for alt/reg are as follows:
    Alternator
    Common to Ford/Mazda Courier P/U 71-80 NAPA #213-8830
    Voltage Regulator
    GP Sorensen #26-5072 (solid state)
    Transpo #IM952
    Ignition parts #'s
    Distributor Cap
    NAPA #EP-710
    Borg Warner #C 585
    Rotor
    NAPA #EP-711
    Contact Points
    NAPA #CS-360
    Borg Warner #A 529
    Condenser
    NAPA #EP-300
    Borg Warner #G 658
    Coil
    NAPA #ICR23
    Ignition Wires
    NAPA Belden 7mm 4cyl #700172 (universal fit but good fit)
    I don't have a starter number but you might look into having yours rebuilt.no start-carb-float-1-jpgno start-carb-float-2-jpg
  3. #3
    Veteran Member alchemysa's Avatar
    Join Date
    Oct 2006
    Posts
    1,395
    South Australia
    Kubota B1550HSD
    Quote Originally Posted by ihuntbear View Post
    I'd suggest its uncommon for a float to be so far out of whack that fuel pours out the overflow. Assuming the float is OK and its been installed the correctly, its more likely that the problem is the needle and seat. It could be worn or theres some grit thats preventing the needle from sealing properly.
    TIME IS RUTHLESS.
  4. #4
    Join Date
    Jan 2010
    Posts
    430
    im just about ready to send this to the scrap dealer..I fix one thing then another thing happens...vicious circle..would like to find a part number for a carb kit and starter kit...It seems it doesn't turn over fast enough to fire up..battery is fully charged..Put new coil on ,new plugs,new condenser,new points,took carb off and soaked it,cleaned gas tank.only fires some times,checked and cleaned all wire connections..float level seems good now...starter is dragging and need a kit for it...after turning it over for a while starter is hot to touch..im going back into the garage tomorrow and pull the starter
  5. #5
    Join Date
    Sep 2002
    Posts
    1,612
    Mt. Ulla, NC
    Satoh S-470D, Mitubishi FD 1450D
    Take the starter to a rebuild shop.
  6. #6
    Veteran Member Lou66's Avatar
    Join Date
    Nov 2012
    Posts
    1,390
    Brazoria county where Texas began
    Deere 990/Montana 5740
    [starter is dragging and need a kit for it...after turning it over for a while starter is hot to touch..im going back into the garage tomorrow and pull the starter[/QUOTE]
    Sound like your insulation on your winding has broken down.. will over time.. a good starter rebuild shop can pull and dip your windings.. most times it is cheaper than a new starter..
    "Life is good if beer is cold"
  7. #7
    Join Date
    Jan 2010
    Posts
    430
    brought the starter to the rebuild shop today..have it back next week...Anybody know what the spark plug gap is??
  8. #8
    New Member
    Join Date
    Dec 2012
    Posts
    8
    Lebanon, Pa.
    Satoh S650G
    Hello all! First time poster. Recently acquired a S650G and have been trying to get here running. Spark was weak so we replaced the points, condenser and rotor as well as all 4 plugs. Spark is now very good as a result. After cleaning out the fuel tank and adding fresh gas we pulled the fitting off at the top of the carb and noticed the fuel volume while turning it over seems low? Does anyone know the NAPA number for the fuel pump or is it better to just go electric? Thanks, Truckman
  9. #9
    Join Date
    Jan 2010
    Posts
    430
    what did u gap your plugs at
  10. #10
    New Member
    Join Date
    Dec 2012
    Posts
    8
    Lebanon, Pa.
    Satoh S650G
    ihuntbear, I gapped them .032" and also pulled the valve cover to verify the timing marks on the harmonic balancer were in the right position when the #1 cylinder was TDC. There are 2 marks on mine. I think the other is for using a timing light to verify the 6 degrees BTDC while the unit is running. Hope this helps. Truckman
Similar Threads
  1. Convert old rope pull start to an electric start
    By docrocky in forum Build-It Yourself
    Last Post: 08-25-2011, 09:00 PM
  2. Replies: 1
    Last Post: 03-31-2010, 10:55 AM
  3. Hard Start/No Start Issue
    By case2273 in forum Construction Equipment
    Last Post: 05-25-2009, 12:57 PM
  4. JD X324 hard start .... now no start
    By rxman in forum John Deere Lawn & Garden
    Last Post: 12-20-2008, 08:17 PM
  5. HELP How do you Start/ Move a BX23 with a bum neutral start switch?
    By LBrown59 in forum Kubota Owning/Operating
    Last Post: 11-12-2007, 07:28 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
