Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 22
  1. #11
    Join Date
    Sep 2012
    Posts
    53
    Denham Springs, La
    Mitlubishi D2350
    Default Re: Need help pulling rear axle
    OK, I've been in the shop most of the day except when I went out to get an impact gun and sockets. I used a chisel to enlarge the hole in the cover a little. Then I stuck a pry bar in the hole and pried the cover off. Easy.
    Need help pulling rear axle-rear-axle-cover-5-jpgNeed help pulling rear axle-rear-axle-cover-6-jpg
    The cover only has the one side-I was mistaken about that-the metal on the other side turned out to be the axle. The pictures below show the axle and the nut with the nut keeper thingy and the bearing behind it. I tapped down the keeper tab to free the nut and used a punch on the corners of the nut and only mild taps were required to turn the nut loose a little.
    Need help pulling rear axle-axle-nut-2-jpgNeed help pulling rear axle-axle-nut-1-jpg
    Next I pulled the rear wheel
    Need help pulling rear axle-picture-004-jpgNeed help pulling rear axle-picture-003-jpg
    I took the nut off and removed the oil pan at the bottom of the axle housing. I put a 5 gal bucket with a 2x6 on top which worked out to be about 1 or 2 inches below the bottom of the bull gear.
    Next I tapped on the wheel flange (where the rim bolts onto the axle) with a dead blow hammer and the axle let go and I pulled it out.
    Need help pulling rear axle-picture-006-jpgNeed help pulling rear axle-picture-005-jpgNeed help pulling rear axle-picture-010-jpgNeed help pulling rear axle-picture-007-jpg
    I cleaned up the housing a bit and called it a night. Tomorrow I need to see if I can get that other bearing off the shaft and bring them somewhere to see if they need replacing. I don't think they look too good but I really don't want to have to replace them as it'll be expensive.
    I'll keep y'all posted.
    Cecil
  2. #12
    Join Date
    Aug 2009
    Posts
    726
    Dallas Oregon
    Mitsubishi MT372, Ford NAA
    nicely done! As an aside I find that bearing are often cheaper at a dedicated bearing supplier rather than a Tractor Supply house or Auto parts store (although not always) good luck!
  3. #13
    Join Date
    Sep 2012
    Posts
    53
    Denham Springs, La
    Mitlubishi D2350
    Thanks. If I need new bearings I'll try Motion Industries or somebody like that.
  4. #14
    Join Date
    Sep 2012
    Posts
    53
    Denham Springs, La
    Mitlubishi D2350
    To replace the seal, the bearing had to come off any way so I wound up getting both bearings. Earlier, when I tapped on the wheel hub to get the axle out, the bearing on the other side just fell out. It seems to be OK but being this far into the thing I decided to get a new bearing. I got a buddy to remove the pressed bearing and oil seal then press the new ones back on.
    I also noticed that the seal "race" which is at the very outside of the axle housing is badly scored and grooved, which is what tore up the oil seal and caused the leaking. When I inspected the seal it was torn better than half way around. So now I'm waiting on the seal race.
    You can see in the pictures how smooth the bearing cup is compared to the seal race.
    Need help pulling rear axle-picture-013-jpg
    Need help pulling rear axle-picture-019-jpg
    So, for now, I'll be knocking the bearing cups out and installing the new ones while I wait for the seal race.
    Attached Thumbnails Attached Thumbnails Need help pulling rear axle-picture-018-jpg
  5. #15
    Join Date
    Sep 2012
    Posts
    53
    Denham Springs, La
    Mitlubishi D2350
    Knocked out the 2 bearing cups and the race seal today. Pulling the rear axle housing would've been a much better way to do it if I had a shop crane or some other means of lifting it.
    I had to remove the 3 point hitch arms and links and the draw bar & attaching mounting plates.
    Need help pulling rear axle-picture-034-jpg
    I got a big hammer and a long punch and banged away. Because the inner bearing cup was easy to access from outside the tractor I was able to knock it out pretty quick. But for the outside bearing cup and the seal race, I had to lay on my back underneath the tractor to beat out.
    I didn't have much room and the angles I had to work with placing the punch and then trying to hit it with the hammer were bad. After about a half hour I had made no progress so I got my propane torch and heated the axle housing and was able to drive both of them out.
    Need help pulling rear axle-picture-025-jpgNeed help pulling rear axle-picture-024-jpgNeed help pulling rear axle-picture-023-jpgNeed help pulling rear axle-picture-022-jpg
    The wheel hub with new bearing and seal
    Need help pulling rear axle-picture-028-jpgNeed help pulling rear axle-picture-026-jpg
    Close up of seal
    Need help pulling rear axle-picture-027-jpg
    The bull gear
    Need help pulling rear axle-picture-029-jpg
    The seal race
    Need help pulling rear axle-picture-032-jpgNeed help pulling rear axle-picture-031-jpgNeed help pulling rear axle-picture-030-jpg
    Hopefully tomorrow I can drive the new bearing cups in. Then I'll only have the seal race to install and then reassemble everything.
    Attached Thumbnails Attached Thumbnails Need help pulling rear axle-picture-021-jpg   Need help pulling rear axle-picture-033-jpg
  6. #16
    Join Date
    Jun 2010
    Posts
    1,463
    Southern California
    International Harvester 284, Yanmar 1401D, Yanmar 240...etc
    This is a great writeup, good job. Have you been able to match the bearings?
  7. #17
    Join Date
    Sep 2012
    Posts
    53
    Denham Springs, La
    Mitlubishi D2350
    Thanks. Amazingly enough, in the "Removing the Wheel Shaft" section of the service manual there is a drawing showing the different parts and the bearing numbers are included. The parts book says "bearing". I ordered them day before yesterday and picked them up yesterday. They are different sizes.
  8. #18
    Join Date
    Sep 2012
    Posts
    53
    Denham Springs, La
    Mitlubishi D2350
    Today I cleaned up the bore and installed both bearing cups. I received the seal race and plan on installing it tomorrow.
    New cup installed for outside bearing
    Need help pulling rear axle-picture-035-jpg
    New cup installed for inside bearing
    Need help pulling rear axle-picture-037-jpg
    The service manual gives a procedure for preloading the bearings but it assumes that the rear axle housing has been removed from the tractor with the final drive shaft also removed, allowing the axle to be turned and preloaded. I haven't removed the housing and the bull gear, which is attached to the axle will be meshed with the final drive shaft, making it impossible to measure the preload torque specified. I'll have to figure this one out.
  9. #19
    Join Date
    Sep 2012
    Posts
    53
    Denham Springs, La
    Mitlubishi D2350
    So, what I did was to install the wheel hub without the bull gear in place. I used my lathe and drill/mill to fabricate a wrench to fit the axle nut.
    Need help pulling rear axle-picture-052-jpgNeed help pulling rear axle-picture-050-jpgNeed help pulling rear axle-picture-051-jpg
    I tightened the nut according to the manual so that I had the specified preload on the bearings. I noted the torque value on the nut then I removed the wheel hub. I reinstalled it with the bull gear in place and torqued the axle nut to same value as before. Hopefully, that'll be good enough.
    While I was taking the tractor apart the brake rod for the right side had to be removed. The adjusting nut was frozen solid. I wound up breaking off the threaded part of the shaft. I cut the shaft and welded a nut to the end of it. Then I screwed a piece of all thread of the right length into the nut and installed a locking nut. I also made a new part that the adjustment screw goes through and the spacer between it and the adjusting nuts.
    Need help pulling rear axle-picture-057-jpgNeed help pulling rear axle-picture-056-jpgNeed help pulling rear axle-picture-054-jpg
    I cut a piece of sheet metal and welded it to the axle nut cover. I cut a barbed wire staple in half and welded it to the cover so if I need to take it off again (I hope I don't) it may be easier. As you can see, I really need to work on my welding skills.
    Need help pulling rear axle-picture-055-jpgNeed help pulling rear axle-picture-044-jpgNeed help pulling rear axle-picture-046-jpg
    And here is the tractor.
    Need help pulling rear axle-picture-047-jpg
    I still have to put the 3ph on the rear and fill the housing with oil. I'll be running it this afternoon to see how it works. I hope everything is OK because I'm tired of crawling and working under there.
  10. #20
    Join Date
    Sep 2012
    Posts
    53
    Denham Springs, La
    Mitlubishi D2350
    Ran the tractor a little bit yesterday and it seems OK. This morning I drove over to my neighbor's and hooked up to his box blade. Graded my driveway for an hour and returned the box blade. The tractor performed fine.
    Overall the job wasn't too bad and I enjoyed doing the work and now I feel comfortable working on pretty much anything on it.
    284 International and skylarkguy, thanks for your input on the project.
    Cecil
Similar Threads
  1. Pulling a Dexter drum brake axle
    By GreatWhitehunter in forum Trailers & Transportation
    Last Post: 10-08-2009, 12:25 PM
  2. Ym1702 D Rear wheels quit pulling
    By drtracer15 in forum Yanmar
    Last Post: 08-25-2009, 04:22 PM
  3. Tandem axle Trailer,rear axle stuck off the ground
    By jjcc246 in forum Parts/Repairs
    Last Post: 10-07-2005, 07:23 PM
  4. Buying Advice 1510 rear axle seals (advice removing axle or hub)
    By klawson44 in forum Yanmar
    Last Post: 05-22-2004, 08:52 PM
  5. 8N rear axle
    By gspig in forum General Vintage Tractors
    Last Post: 09-13-2003, 12:47 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
