Results 1 to 10 of 10
  1. #1
    Join Date
    Nov 2011
    Posts
    178
    John Deere Garden Tractors
    Default S373D 4x4-front axle seals
    Anyone ever gone through and replaced them? When I got the tractor the front spindle/hub areas were all greasy, and the level in the front axle is way down. Want to get some fluid in there but not if its all going to leak out again.
    Its more of a step down design then some of the other tractors with the big ball shaped pivots like on the S370 I believe.
    Not mine, but an example attached.
    Attached Thumbnails Attached Thumbnails S373D 4x4-front axle seals-89680869.jpg
    Mitsubishi/ Satoh S-373D and TWO MT372 Compact Tractors
    John Deere 70, RF110, 332, 345, and 420 Garden Tractors, Struck MD45 Dozer
  2. #2
    Join Date
    Sep 2002
    Posts
    1,297
    Mt. Ulla, NC
    Satoh S-470D, Mitubishi FD 1450D
    Default Re: S373D 4x4-front axle seals
    I've done it on both of mine, should be exactly like yours. It's not that bad. I remember doing the Buck first and think there is a bushing that had to be pressed in. Will try to remember to look at my books when I get home. Just don't leave a socket in there like I did. Luckily nothing broke, just made the right front wheel slide now and then.
  3. #3
    Gold Member Ilikeurtractor's Avatar
    Join Date
    May 2011
    Posts
    370
    Iseki TX1300F/TX1500/ TX2160F/TS2220F/ Satoh S373D
    Quote Originally Posted by duwem View Post
    I consider this design superior to the universal joint design (ball style). This design allows a tighter turn radius and also better ground clearance (comparing the same tractors and their respective designs). The seals are relatively expensive and not that easy to come by and are a specialty seal for the S373D front axle. I believe "small import tractor supply" is where I bought them from (need to verify the name) out of Oregon.
    One nice thing about being average is you're not alone.
  4. #4
    Join Date
    Nov 2011
    Posts
    178
    Sounds good, I found a service manual showing the breakdown.
    Anxious to know about the seal avaliability/cost.
    Thanks.
  5. #5
    Join Date
    May 2011
    Posts
    370
    Expect about $20-25/ea for the final drive housing seal and to have it ship from Japan. This seal is noticeably thin and will require some machining to be done on the drive housing components to "retrofit" a standard seal once they are no longer available - if it's even possible. Originally the seal was composed of two separate thin lip-seals but have later been replaced with a single but double-lipped, thicker seal (still fairly thin though) w P/N 10070641001. I've heard there are some businesses that can custom make seals like this but I'd expect the price to triple or quadruple for 1 and 2 quantities. The other seal is standard metric you can get cheaply off ebay. It might not have the metal face but will still work.
  6. #6
    Join Date
    Nov 2011
    Posts
    178
    Yeks, anyone ever tried Valley Power or others for the seals?
    How many are there per side one would want to replace?
    Here is the diagram from the shop manual.
    Attached Thumbnails Attached Thumbnails S373D 4x4-front axle seals-front-end.jpg
  7. #7
    Join Date
    May 2011
    Posts
    370
    There are only two seals (if you count the P/N from my last post as one) and one O-ring per side that goes from the final drive to the axle housing. See attached....
    Attached Thumbnails Attached Thumbnails S373D 4x4-front axle seals-satoh-373d-front-axle-parts_page_1.jpg   S373D 4x4-front axle seals-satoh-373d-front-axle-parts_page_2.jpg   S373D 4x4-front axle seals-satoh-373d-front-axle-parts_page_3.jpg
  8. #8
    Join Date
    Sep 2002
    Posts
    1,297
    Mt. Ulla, NC
    I replaced 2 number 27's on each side. That was where it was leaking. Also replaced the bushings, #26. I got the parts from Valley Power and don't think the seals were all that bad but it was a long time ago.
  9. #9
    Join Date
    Nov 2011
    Posts
    178
    What seals the cases together like 7 to 15, 38 to 15, 28 to 20? Just RTV or is there gaskets there, dont see gaskets on the breakdown.
    I suppose it wouldnt be a bad idea to replace seal 34 as well.
  10. #10
    Join Date
    May 2011
    Posts
    370
    The case covers that don't have a shaft going through them just use a sealant compound - silicone works fine.
Similar Threads
  1. GR2100 front axle seals
    By oldgoatvt in forum Kubota Owning/Operating
    Last Post: 04-21-2012, 11:48 AM
  2. L35 Front Axle Seals
    By cheekme in forum Kubota Owning/Operating
    Last Post: 04-20-2009, 04:23 PM
  3. Front axle seals, GC 2310
    By plowking in forum Massey Ferguson Owning/Operating
    Last Post: 05-10-2008, 08:57 PM
  4. ym 2000 4x4 front seals
    By runningbird in forum Yanmar
    Last Post: 04-26-2007, 12:48 PM
  5. Front Axle fluid and Seals
    By bobjr1 in forum Yanmar
    Last Post: 02-23-2006, 06:59 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
