Results 11 to 20 of 23
02-09-2013, 10:28 PM #11Member
- Join Date
- Sep 2012
- Posts
- 43
- Location
- Denham Springs, La
- Tractor
- Mitlubishi D2350
Re: Clutch pedal blocking while in storage
02-10-2013, 03:20 PM #12Veteran Member
- Join Date
- Sep 2002
- Posts
- 1,300
- Location
- Mt. Ulla, NC
- Tractor
- Satoh S-470D, Mitubishi FD 1450D
I'll try to get a shot of mine.
02-10-2013, 05:42 PM #13Elite Member
- Join Date
- Jun 2008
- Posts
- 4,735
- Location
- Bismarck Arkansas
- Tractor
- 2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
Just push in on the clutch and the wedge between the clutch pedal and that piece of angle should work fine. That is similar to what we did with my brother in laws JD.
2010 LS P-7010C 20F/20R gear tractor & FEL, 2009 Kubota B 26 TLB, RTV 900 Kubota, 2012-20 ft 12k GVW trailer, 2011- 52" Craftsman ZTR mower, 54" John Deere 332 lawn tractor, 5.5HP rear tined walk behind tiller, 7 foot bush hog, 8 foot landscape rake , 8 foot 3 PH disc, 2 row cultivator, 350 amp CC/CV AC/DC welding machine and a shop full of tools that I spend more time looking for than using.
02-10-2013, 05:47 PM #14Super Member
- Join Date
- Nov 2011
- Posts
- 6,460
- Location
- Ohio
- Tractor
- Kioti DK 40-Massey ferguson 135-Simplicity Conquest
You guy's got me to wedge a block of wood in my MF 135 clutch pedal, I hope I don't screw anything up.
02-10-2013, 05:54 PM #15Elite Member
- Join Date
- Apr 2004
- Posts
- 4,767
- Location
- Bay Area-Ca and Olympia WA
- Tractor
- Cat D3, Deere 110 TLB, Kubota BX23, Craftsman Mower
I've had a few service calls with antique cars that were parked over winter and the clutch was frozen.
So far, I have been able to get all free... sometimes it was as easy as push starting and driving will clutch fully depressed.
One time, the fellow didn't want to pay for a tear down... he said he poured hot water into the clutch housing and it broke free.
02-10-2013, 07:19 PM #16Member
- Join Date
- Sep 2012
- Posts
- 43
- Location
- Tractor
- Mitlubishi D2350
Lots of great replies and suggestions here-thanks a bunch. Didn't have much going on this afternoon so I played around with it. I drove that piece out of the clutch pedal arm and did a little experimenting.
I welded this together. It's ugly but it's only a starting point.
Pictures of it doing it's job
I need to beef it up a little but I think it'll work. When I do the finished product I'll weld another piece across the top so that when I let it down, it'll rest on top of the arm instead of hanging down.
I set it to hold the pedal down but not far enough to activate the safety switch so the tractor can't be started by turning the key.
The pedal is held down enough that I can push the tractor while it's in gear so I feel like the clutch is disengaged enough.
Thanks for all the info.
Cecil
02-10-2013, 07:43 PM #17Veteran Member
- Join Date
- Sep 2002
- Posts
- 1,300
- Location
- Mt. Ulla, NC
- Tractor
02-10-2013, 08:56 PM #18
On my 790, I use a short block of 5/4 x 6 decking material. It holds the pedal down and fits just right between the pedal and floorboard. Guess I never looked to see if there was a pin or latch on mine.
Greenrancher
**2006 JD790, FEL
**2005 JD X495, 62" MMM
**1996 Grasshopper 54" ZTR
**197? International Lo-Boy, 60" belly mower
02-11-2013, 04:14 AM #19Super Star Member
- Join Date
- Nov 2001
- Posts
- 15,682
- Location
- Bethel, Vermont
- Tractor
- John Deere 4400 MFWD
Roy Jackson
A fear of weapons is a sign of retarded sexual and emotional maturity...
02-11-2013, 01:17 PM #20Member
- Join Date
- Sep 2012
- Posts
- 43
- Location
- Tractor
- Mitlubishi D2350
The clutch pedal hold down bracket is complete.
Here it is doing it's job
Here it is when I'm using the tractor
Again, thanks for all the suggestions, pictures and such. It gave me a lot of food for thought. As was suggested, I could have used a block of wood to wedge between the clutch arm and floorboard but I have a lathe, mill/drill, welding machine and time on my hands(laid off). Plus I need practice on all those machines.
My tractor doesn't have a grill so that'll probably be my next project. I'll be in touch.
Cecil
Similar Threads
Blocking a wet disk clutch
By RoyJackson in forum John Deere Owning/OperatingReplies: 12Last Post: 12-26-2010, 01:28 AM -
clutch pedal question
By MF1652 in forum Owning/OperatingReplies: 4Last Post: 07-14-2010, 02:49 PM -
Blocking the clutch on a 4400
By RoyJackson in forum John Deere Owning/OperatingReplies: 3Last Post: 06-08-2010, 12:08 PM -
Blocking the clutch pedal
By GrantMO in forum Kubota Owning/OperatingReplies: 20Last Post: 02-13-2002, 11:46 AM -
Clutch pedal on hydrostat
By Anonymous Poster in forum New Holland Owning/OperatingReplies: 10Last Post: 09-17-2000, 12:16 PM
