Page 1 of 2 12 LastLast
Results 1 to 10 of 12
  1. #1
    Bronze Member Utah Bison's Avatar
    Join Date
    Mar 2013
    Posts
    58
    Utah
    S650G Bison Ferguson TO30
    Default Bison in a box
    Here she is my Bison in a box was delivered this weekend.
    Bison in a box-bison-117-jpg
    So far im pretty happy. Seems its all here except for the governer cover.
    Started putting it together and checking things over to find. One push rod
    wasn't in the lifter correctly, and the valves needed some serious adjustment.
    Had to grind off the exaust studs and extract the remains. Flaten the manifold and pipe
    install new studs and exaust leak worries are done with. Looking down the plug holes is a nice new cross hatch finish so the cylinders were refinished for new rings that was refreshing to see. And the engine is sparkling clean inside.
    Had to fix up and service the distributor and advance systems. Added some fuel to the carb bowl and cranked her over a bit and it fired right up and sounded good. Peeping through the oil fill hole the rockers were oiling nicely. Added the radiator to find a leaking water pump. o well what can ya expect? Next a rewire, Install the water pump when it gets here, Fix the tractrmeter Clean and overhaul the carb and gas tank lube it all good
    then go to the hydralicsBison in a box-bison-114-jpg
    Lee
  2. #2
    Super Star Member
    Join Date
    Jul 2011
    Posts
    14,436
    Yanceyville, North Carolina
    Kubota L4400
    Default Re: Bison in a box
    It appears that you have quite a Project ahead of you. Best wishes.
    The PUPIL who does not surpass his Master, fails his Master.
  3. #3
    Join Date
    Mar 2013
    Posts
    58
    Utah
    Well while waiting for the water pump i figured i should check out the steering box.
    First visual inspection the oil appeared nice and clean......But come to find out it was 1/2 of
    oil on 3 inches of water. Plus the upper rubber bushing in the column was worn making the
    steering wheel slop side to side some,and up and down. The bearings and gears all survived
    there water bath just needed a good cleaning and reassembly. I added a .005 shim on the upper sector shaft race to tighten it's bearings a bit. On the upper steering column
    I decided to use a sealed bearing instead of a rubber bushing. 42mm OD 20mm ID 12mm thick
    was a perfect fit and took all vertical and horizontal movement out of the steering wheel and
    rotates smooth as silk. Glad I checked into this and have it finished so I can move on since the water pump came today.
    Clean pretty gear oil nowBison in a box-bison-004-jpg
    The new steering shaft bearing
    Bison in a box-bison-003-jpg
    Lee
  4. #4
    Join Date
    Mar 2013
    Posts
    58
    Utah
    Well the Bison is coming together nicely and the box is empty
    The engine purrs like a kitten. I'm very pleased with how it runs and sounds.
    I didn't clean and paint it much now wanting it to work to earn its keep.
    Bison in a box-bison-ii-007-jpg
    Got the loader installed now and all new hydro hoses ordered.
    Bison in a box-bison-ii-004-jpg
    Bison in a box-bison-ii-008-jpg
    Found out I had no right brakes and upon inspection found the lining had come
    off the webbing and ground it's seft to dust. So the brake shoes are getting relined now.
    Gotta have good brakes. Cool brake system and everything else was in excellent shape.
    So another 40.00 is worth it.
    Bison in a box-bison-ii-003-jpg
    It's all rewired now. Got a new seat and made its mount. And all my sheet metal, Hood,Dash,Fenders,
    Tool Box, Head lights,seat mount ect. went to a buddy for powder coating. Nice not having to mess with
    blasting and painting only to have rust in a few years. Now he wants the loader off to powdercoat it too.
    I figure in a week or two I will have a darn nice tractor and be under the 2000.00 I was hopeing for.
    Untill I have more
    Lee
    The one part I found I'm missing is the governer shield. If anyone has a extra they might sell let me know. Or I will just make one...Thanks
  5. #5
    Join Date
    Aug 2009
    Posts
    726
    Dallas Oregon
    Mitsubishi MT372, Ford NAA
    Default
    Neat. Coming together nicely....i need a buddy who powdercoats!
  6. #6
    Platinum Member techwrtr2's Avatar
    Join Date
    Nov 2007
    Posts
    846
    Alabama PA
    Which one?
    Who made the loader for that Bison? Kind of reminds me of the Blackhawk on my Beaver.
    I like to play in the dirt....
    Satoh Beaver w/Blackhawk loader & hoe.
    JD855 w/stuff.
  7. #7
    Join Date
    Mar 2013
    Posts
    58
    Utah
    It's a National loader. Got my new hydro lines for it today. Also got all my sheet metal back from
    getting powdercoated. Shes gonna be purdy.
    Lee
  8. #8
    Join Date
    Nov 2007
    Posts
    846
    Alabama PA
    Which one?
    Interesting on the loader.
    They are connected it seems. "Black Hawk" is a name that appears on my loader and hoe. However the manuals have Johnson "Work Horse" on them. Bottom of each manual references the ARPS division of Chromalloy. Your loader was built by Johnson Hydraulics of MN who was purchased by ARPS.
    So they are from the same company.
    Found a brochure on eBay too. 1967 National Loader Model 16 for Satoh S650 Tractor Brochure MX5088 4Z8N2U | eBay
    JD855 w/stuff.
  9. #9
    Join Date
    Mar 2013
    Posts
    58
    Utah
    Yep I found the sticker saying Johnson Hydraulics. What color is your blackhawk? Mines like international yellow. After getting everything back from powdercoating I decided to take the loader back off and send it to get coated to. So nice being clean and all finished. I'm going with red and black cylinders.
    The Bison has come a long way since it got out of it's box.
    Bison in a box-wedding-sunset-062-jpg
    Lee
  10. #10
    Join Date
    Nov 2007
    Posts
    846
    Alabama PA
    Which one?
    It's a kind of off white. At least it was. More white rattle can now than not. May repaint it one of these days when I have time to tear it down and fix its various woes.
    JD855 w/stuff.
Similar Threads
  1. Bison 25 1992
    By rwalton in forum Owning/Operating
    Last Post: 06-23-2011, 01:44 PM
  2. bison 25
    By ynnadresoob in forum Parts/Repairs
    Last Post: 05-01-2011, 04:47 PM
  3. Shennui bison 25
    By bubbyc2005 in forum Parts/Repairs
    Last Post: 01-28-2009, 12:52 AM
  4. Box Scraper Bison Box Blade + width ??s
    By lars in forum Attachments
    Last Post: 05-23-2008, 12:29 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
