Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
  1. #11
    Super Star Member J_J's Avatar
    Join Date
    Sep 2003
    Posts
    18,924
    JACKSONVILLE, FL
    Power-Trac 1445, KUBOTA B-9200HST
    Default Re: Hydraulic Issues - Diagnostic help
    If this is an open center hyd system, and the hyd flow is like this. Pump to loader, to 3pt , to tank.
    Since all pump fluid flows through all valves, there should be no pressure when the valve levers are in neutral.
    The loader spools if working normal, should block all flow to the loader cylinder.
    I could see this happening if the loader valve spool is not returning to center so that when you cause the pressure to build by using the 3pt, therefore blocking the fluid, will cause the pressure to build up and affect the loader valve.
    Did yo?u make any changes to the hyd lines before this happen
    J.J.
    When I works, I works hard. When I sits and thinks, I goes to sleep.
    Git er done.
  2. #12
    Super Member Xfaxman's Avatar
    Join Date
    Feb 2013
    Posts
    7,988
    Meridian, OK
    Bobcat V417 Toolcat 5610 G TORO+Loader
    Quote Originally Posted by sruman View Post
    See Picture (drawing) attached. This may help us get a clearer picture on the hydraulic system. Pretty basic.
    oldnslo: to answer your question, it takes ALOT of force to move them, barely humanly possible. The handles are being pushed toward the front of the tractor (away from driver).
    kennyd: The fluid distributor is a "box" that the power steering lines ties to. Nothing more than that (see pic).
    By looking at the pick, I think the line 2 (from box B to D) is either clogged, or the distributor (Box B) is clogged. Reason: when I raise the 3PH, rather than fluid come from distributor box (Box B, line #2 on diagram), is it sucking the fluid from FEL Control (Box C). I cannot think of any other reasonable explanation. Again, I'm no mechanic, but it makes logical sense to me. Unless anyone has a better idea, I'm going to tear apart that box and line and make sure they are clean.
    Attachment 311714
    That is not the way hydraulics work. Your problem is flow is going in the out port of the loader valve, causing the bucket to dump and the lift cylinders to retract. When did this start happening?
    My idea is the problem is in the 3PH circuit.
  3. #13
    Join Date
    Sep 2003
    Posts
    18,924
    JACKSONVILLE, FL
    It is normal for the 3pt to cause a pressure buildup when the lever is held in the raise position, and the relief valve will sound off, and the relief pressure will back up into any valve upstream and cause problems.
    If the up stream valves and spools are working, the loader cyl should not operate with the back pressure. If you try and use the loader with the 3pt lever raised, the back pressure will work against the pump pressure and cause problems in the valve, and possibly blow the seals.
    J.J.
    Git er done.
  4. #14
    Join Date
    Feb 2013
    Posts
    7,988
    Meridian, OK
    Quote Originally Posted by J_J View Post
    J.J., in his drawing the 3pt is before the loader. The plate on the 3pt reminds me of the old Massey Ferguson system for adding a cylinder. You had to lock the lift arms to use it.
  5. #15
    Join Date
    Feb 2013
    Posts
    7,988
    Meridian, OK
    I have a Satoh 650 and I have a unique problem that is occurring, and not sure the answer. I've read many many threads, but cannot find a reasonable answer/assistance with my particular issue.
    Thanks in advance.
    Matt in PA.
    Please answer our questions.
    Did it ever work right?
    Did you make any changes to the hyd lines before this happened?
  6. #16
    Join Date
    Sep 2003
    Posts
    18,924
    JACKSONVILLE, FL
    Quote Originally Posted by Xfaxman View Post
    On most tractors, without loaders, the pump fluid goes to the 3pt, and there is some kind of distribution unit somewhere, similar to the kubota hyd block.
    When a loader is mounted, the fluid is now routed to the loader first and back to the hyd block, and then to the 3pt.
    He could easily take a hose off and verify the flow path.
    A hyd gage would help with the troubleshooting.
    It is just not logical to have to raise the 3pt when you want to use the loader.
    Which relief valve has priority, 3pt or loader?
    J.J.
    Git er done.
  7. #17
    Join Date
    Jul 2011
    Posts
    98
    Shermans Dale, PA
    Ford 1910
    1. They never worked since I bought it (3 yrs ago). Just now getting around the trouble shooting.
    2. I did not make any adjustments or mess with the Hydraulics.
    3. I think I have a bigger problem now. I have coolant running out of my oil pan seal. I'm going to go out on a limb, and say this is not good, and the engine is now junk.
    Anyone need a used Satoh that needs a new engine? Where could you even pick up an engine for one? Cost? I'm thinking that it's not worth fixing, and probably need to just part it out. There are many new parts and tires that have value.
    Thoughts?
  8. #18
    Join Date
    Feb 2013
    Posts
    7,988
    Meridian, OK
    Thoughts?
    I think you should start a new thread in this forum about the leak, and if you want to sell it, list it here: Private Party Ads, and on craigslist.
Similar Threads
  1. diagnostic codes for bobcat
    By gman182 in forum Bobcat Construction Equipment
    Last Post: 08-25-2010, 09:03 PM
  2. Diagnostic message
    By sidewalk_man in forum Toolcat
    Last Post: 11-19-2008, 12:27 PM
  3. EHydro diagnostic flash codes
    By Dave4410 in forum John Deere Owning/Operating
    Last Post: 08-18-2004, 10:24 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
