Results 1 to 4 of 4
  1. #1
    New Member
    Join Date
    Oct 2013
    Posts
    3
    Dallas, GA
    MTD1601D
    Default MT1601D clutch advice needed please
    MT1601D clutch advice needed please-photo-3-jpg
    I'm working on un-sticking the clutch plate from the flywheel. I split the tractor tonight and you can see what I found when I opened it up in the attached picture. I have loosened the bolts from the flywheel in hopes of it breaking loose. I can turn a wrench but I suck at diagnosing. Can anyone tell if this will/has worked from the picture? This is the first time I have attempted this on a tractor, so I don't really want to pull out completely apart for fear of having a 1000lb piece of yard art!
    Thanks for your advice in advance.
  2. #2
    Join Date
    Sep 2002
    Posts
    1,612
    Mt. Ulla, NC
    Satoh S-470D, Mitubishi FD 1450D
    Default Re: MT1601D clutch advice needed please
    Welcome to TBN. While I don't have a direct answer, you can search this and other forums and see that this has been covered many times. It is a problem common to probably all brands. Many times, folks will block the clutch pedal down and hook a bush hog to the tractor and run it until the clutch breaks loose. This of course is done without splitting the tractor. Also some will hold the clutch down and hit the brakes while rolling. I can't tell much with the size of your picture. The sticking clutch will happen when moisture gets in the bell housing. While you have it apart, check the release and pilot bearings. Also you might want to put a thin film of anti-seize on the transmission input shaft.
  3. #3
    New Member
    Join Date
    Oct 2013
    Posts
    3
    Dallas, GA
    MTD1601D
    Thanks. I did try breaking it free while running to no avail. I got it to come loose and cleaned the corrosion off. Hopefully that will do the trick. Now to get it back together without having bolts left over....
  4. #4
    Join Date
    Aug 2009
    Posts
    724
    Dallas Oregon
    Mitsubishi MT372, Ford NAA
    I'd second what oliver said. check pilot bearing (lube if necessary) and throwout bearing as well. Also check the spring fingers on the pressure plate...make sure they are all there.
Similar Threads
  1. MT1601D Starter/Clutch
    By Bedruggled Old Moose in forum Mitsubishi/Satoh
    Last Post: 05-12-2013, 03:43 AM
  2. MT1601D clutch
    By tucktractor in forum Mitsubishi/Satoh
    Last Post: 05-07-2013, 02:00 AM
  3. MT1601D Manuals needed
    By MackT in forum Mitsubishi/Satoh
    Last Post: 10-16-2009, 10:39 PM
  4. Clutch needed
    By chas in me in forum Kubota Owning/Operating
    Last Post: 09-21-2006, 08:45 PM
  5. MT1601D hydraulics
    By bigcheese in forum Mitsubishi/Satoh
    Last Post: 07-13-2006, 11:22 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
