BladeMech
I am working on a S-370D and all the sudden the clutch pedal does not return (seems to have a return spring missing) and the clutch does not engage even when you manually pull up on the pedal. I can shift into all gears but I can't get the tractor to move under it's own power. I can push the tractor fine in neutral.
The area of the tractor I was working on was the cooling system (radiator and water pump) so I don't think anything I did caused the issue but I have little to no experience on these machines.
Thanks,
Jeff
Thanks,
Jeff
