OP
Capricious
Photo of right-side of engine. Oil pressure sender in center, black-painted oil filter over on the left
i have a set of mechanical gauges on the way. Would like to keep the idiot lights if not a big hassle. What are those (2) allen-head plugs, on either side of the sender unit, and can I plump in the mechanical gauge tube to one of those? If not, I'll just ditch the sender for the light.
In regards to the BPS threaded oil sender hole, I have in hand the adapter mentioned in this thread:
http://www.tractorbynet.com/forums/mitsubishi-satoh/242494-rpm-oil-pressure-water-temp.html
(Thank you, Oliver28472)
Would like to keep the temperature light as well. Might install the tube for the temperature gauge in the threaded opening above the oil filter:
There is an elbow in this hole, with a hose leading to the bottom of the radiator, with a drain petcock located in the middle of the hose. This appears to be a factory set-up:
View attachment page 2 10 MT160 Mt180 service manual.pdf
(Drawing, lower right corner)
I am not sure if coolant can run between the block and the radiator through this line, or if the petcock closes-off flow through the hose when in the "closed" position. I don't see why coolant would NEED to flow through this hose- earlier tractors do not seem to have this hose.
Or, I could just replace the temperature light sender as well.
