I have a I believe, MT180D. Its 4 wheel drive with a 3 cylinder diesel. This tractor was in a garage that burned down. It's current wiring is just enough to run it (starter key switch, push button for glow plugs, one wire alternator) I would like to re wire it.
1. What size should I fuse it for the glow plugs?
2. What length of time for glowplug operation? I will probably use a timing relay.
3. Also this machine has blown up two batteries since I have had it, about 5 years or so, always while cranking with a really low charge, never any other time.
Would the starter cause this? Maybe the fire damaged the bearings allowing the internals to touch shorting??
The one-wire alternator has never put out over 14.8 volts everytime I have checked it at different RPMs.
Thanks for any and all help
Tim.
Tim.
