Steve G
Member
My D-1600 is in the shop. Left rear wheel-hub bearings are shot. Called today and was told two were easy enough to find, but having a very hard time finding the bearing that goes over the shaft at point of entry through the transmission housing (at least that's the one I think is the issue - haven't been in to shop to look at it myself). If all else fails, thinking best way to maybe run one down is pull undamaged bearing from right hub and get a number off of that. The bearing to be replaced is too damaged to lift a number. Local bearing houses drawing a blank.
If any of you guys have been down this road and/or have a D-1600 parts manual and can steer me in the right direction it would be much appreciated. Also having trouble finding some seals but have no specifics on that.
Many thanks in advance,
Steve
Steve
